wanting to get better fuel mileage can i do it
Originally Posted by stlhrse
hah, I would love to get 12. I have an 05 FX4 with no lift, stock tires and wheels and the whole bit. I usually get around 10. I do mostly in town driving. My Dad has an 05 Expedition and he gets like 14-15 in town. I'm taking it in to the dealership on Wednesday to see if they can figure out why the mileage is so bad. I know it's a truck, but sheesh.
The 04 in my sig gets at round 15-16 in town, but I take it easy on acceleration.
Some people say keep it under 2,000 RPMs, and gas mileage will improve.....I keep it under 1,500 RPMs while accleration, and I don't do over 60.
Originally Posted by 01redcrew
has anyone done the gear swap on this model of truck? Also should i ask for 456 gears or something different? Also would that 1200 or more be with labor
I'd say 4.56 gears would be a good choice, but 4.30 or 4.88 might be a option depending on your situation, and how much you use the truck to tow.
The $1,200 would be will labor
My shop charges $300 labor per axle, so for two axles, half the price is labor alone.
4.10 gears would bring you back to a stock effective gear ratio, but 4.30 gears would help more with acceleration, and if you would of had 3.55 gears, then 4.56 gears would of been a good choice.
I'd either go with 4.30 gears or 4.56 gears if you do it, 4.10 gears just wouldn't be worth the money.
i wish i could just order the rear than the front so i wouldnt have to spend over 1200 bones at once
i have a 04ex cab with 35s and im geting around 12 or so mpg i DO baby the truck and thats what i get. The truck as straight pipes and a k&n drop in filter and thats all.
thanks for any help
thanks for any help
You may not like this response, but you spent good money on a 3.5" lift and 35 tires, then you complain about fuel economy? What did you expect? You have significantly increased rolling resistance, as well as aerodynamic drag due to the added lift. Sure, you could throw more money at it by adding an edge, or chip, then throw more money at it by putting in lower gears.
So you "invest" $2-3000 in all of these mods to maybe increase your mileage to say, 15mpg. If gas is $3.00/gal, you would have to drive 40,000-60,000 miles to break even.
If it was me, (of course I'm an old fart now and couldn't care less about being cool) I would put the stock tires and wheels back on and run 45-50 psi in the tires. Your fuel economy will definitely improve, and it won't cost you a dime.
Dale
#28
http://www.yuccaman.com/jeep/speedo.html
Check this web site out. It will explain the tire size change effect on gear ratio and help you determine next gear size. You will just need to know current tire size vs. new tire size.
Good Luck
Good Luck
