starting problems, and EBPV trouble
my 97 upon startup is cranking several times, then firing, and will die if i dont hold throttle down. i changed CPS last week and thought that fixed it, but today it done it again. it will die if the throttle isnt held about 1/2 down. Do you all think it could be from me running 2 quarts of lucas in the oil? causing the oil to be so thick when cold that the injectors cant hardly handle it? i changed fuel filter again today, flushed out bowl too. maybe the fpr screen?
and...i think the the ebpv is sticking under light throttle pressure. drive along light pressure, and feel a jerk like i been hooked to 20,000 pounds and a whoooooooshhhhhh and then thhhp and it goes on, especially after more throttle pressure. i unplugged the EBPV connector just tonight. HELP
and... after the caution lights are on a while the ABS light comes on. turn them off, and it goes off.
and, my left turn signal indicator light sometimes don't come on when i put the signal on.
i know it sounds like alot, but its all minor, and i guess a 10 year old truck deserves a little attention.
