Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 11-28-2007, 11:20 PM
slimtim86's Avatar
slimtim86 is starting off with a positive reputation.
Question ignition/fuel nightmare
So I just got done rebuilding the carborator (2 bbl holly) off of my 292 ('60 f-250). While the carb was off I also changed my plugs, wires, points, rotor, cap, coil, and vacuum advance. Now that I have put it all back together it won't start. With my foot off of the gas it just turns over and nothing else. With foot on the gas or spraying some starting fluid into the throttle body it starts to cough out of the carb. I am almost positive that all of my ignition wires are hooked up in the correct fireing order (15486372) and my spark is good. I'm at a loss because it ran fine before this minus some carb issues. Any words of wisdom?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 11-29-2007, 02:35 PM
RCA78SS is starting off with a positive reputation.
Tim:
I would re-check the point gap (.015") and make sure the wires in the cap are in the right place. They go counter clockwise on the cap.
  #3 (permalink)
Old 11-29-2007, 06:05 PM
Hurk is starting off with a positive reputation.
Wow I am having the same problem. The guyed who owned my truck before said he had the truck runner good. When i replaced all the stuff you said it doesn't start and still isn't. I wish I could help you here. If I could get my started I will try to post something.
  #4 (permalink)
Old 11-29-2007, 10:38 PM
slimtim86's Avatar
I figured out what my problem was. Who ever owned the truck before I did not time the truck properly. When I but cylinder 1 at TDC my rotor was pointing to cylinder 4. I did not pay attention when I had pulled the old wires off, but must have compensated for the wrong distributer position by just rotating the wires three slots over.
Hurk: try taking your cylinder 1 spark plug out, stick a screwdriver in the hole and rotate the crank with a ratchet until the piston taps the screwdriver (TDC), and see where your rotor ends up.
...my point gap is .016"
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
