Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
seafoam
Old 11-21-2007, 02:21 PM
04markIII's Avatar
04markIII
04markIII is offline
seafoam
any of you guys use that stuff? i have in the past, but am skeptical with the s/c and bigger injectors. don't want to f*** stuff up. i have 93k on the motor, much less on the s/c setup.
Old 11-21-2007, 10:06 PM
wd13's Avatar
wd13
wd13 is offline
I use it on occasion, no problems with it.
Old 11-21-2007, 10:17 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
I'm not convinced it does EVERYTHING it claims to do, but it does help clean out carbon deposits.
I wrote up a How-To for SVT Performance and I posted it here too.
Do a quick search using my name and "seafoam" as your criteria and the thread will come up.
I believe I posted it in the Excursion forum.
WD, have you figured out how you plan on attacking your head lifting prob?
Stewart
Old 11-22-2007, 11:31 AM
wd13's Avatar
wd13
wd13 is offline
Stewart
I think I'm gonna go ahead and o-ring the heads and replace the gaskets, studs. Once its all together I'm thinking of making a trip to JJ for some new tunes. I've used JLP in the past with good luck (mostly) but I think its time for a change. I hear JJ is the man when it comes to customer service. I'm also wanting to up the s/c size and exhaust size in order to reduce cylinder pressure without losing hp/tq
Old 11-22-2007, 01:13 PM
Stewart_H's Avatar
Stewart_H
LOL! Ok, I should have read this post before responding in my KB/Whip thread! I basically suggested exactly what you plan on doing.
JJ is excellent when it comes to customer service.
I assume you're gonna ditch the ARP studs for some ARP 2000's?
Stewart
Old 11-22-2007, 07:09 PM
wd13's Avatar
wd13
wd13 is offline
Stewart
I was under the impression that I had the 2000's. Dont know. I will make sure thats what they are this time. lol
Old 12-12-2007, 10:51 AM
04markIII's Avatar
04markIII
i added it to the gas tank and crankcase yesterday as i am having the oil changed next tuesday for my trip to FL on the 25th. this weekend i want to added the correct amount to the main vacuum line and clean the rest of it out(cant wait to see the smoke show, 93k on engine)....but which line is the main vacuum line?
edit: n/m, i found it. looks like i should find a helper.
Old 12-15-2007, 09:50 AM
04markIII's Avatar
04markIII
attempting this today. i filled a baby bottle with just over 5oz, and i'm going to let it drip into the vacuum line. hopefully, with 93k miles, i will get a good cleaning.
Old 12-17-2007, 02:28 PM
04markIII's Avatar
04markIII
had a tech here at work help me out. we went with a smaller vacuum line and sucked it all in instead of letting it drip in. i was hoping for a big smoke show with 93k miles, but nothing major really. oh well, guess the engine was clean!
Lariat02
06-06-2008 09:58 PM
04markIII
60
02-02-2007 07:59 AM
Mike12pt
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
05-17-2006 06:31 PM
TurboTuff
06-30-2002 07:09 AM
Quick Reply: seafoam
