86 460 pump location
I am having fuel supply trouble to my carb. Does the 86 have electric pumps in the tank? My manuals arent specific... I havent checked for the inertia switch or pump relay casue I wasnt sure of the pump type. My truck isnt at the house so I am trying to study up on the problem.... thanks folks.
Thanks Bear, my deal was that the oil pressure switch (or wires) was bad. For other folks... The power to the fuel pump sequence goes >oil pressure switch>inertia switch>fuel pump. With the key in the ON position, jumper the oil pressure wires and you should hear the in-tank pump run. If you dont, then check the inertia switch. I am sure there is a fuse somewhere and possibly a fuel pump relay but I didnt find one...
Originally Posted by nsshull
So how do you tell if the pump is bad vs these other problems?
