Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > New York Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
New York Chapter Join Chapter, Leader: tiny1
  #1 (permalink)
Old 11-15-2007, 09:49 PM
dennisg dennisg is offline
Garage is empty, add now
dennisg is starting off with a positive reputation.
Power door lock relay help
HI All, I have been reading different posts of this forum, and it sounds like you have a good group of friendly, helpfull people here. I hope that I will be able to add to it, from time to time.
MY problem is this. I have a 1999 F250SD, 7.3 Diesel, the power door locks only lock, they will not un-lock, I here a slight noise from the bolth actuators, but nothing happens. It does not matter if I use the button on the drivers door , passenger door, or the key fob, for the alarm, the result is the same.
I think that the door lock/un-lock realy is getting tired. I purchased a new one from ford, but they were not able, (unwillijng) to tell me where it is located in the truck. I do not have access to a shop manual. the owners manual does not list it. can anyone help???
Thanks, Dennis
  #2 (permalink)
Old 11-16-2007, 07:17 PM
Ronin007's Avatar
Ronin007 Ronin007 is offline
Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.Ronin007 has a great reputation on FTE.
Hey Dennis. Welcome to the NY Chapter forum. To answer your post check out this thread:
http://www.ford-trucks.com/forums/44...cks-fixed.html
It has gotten huge (15 pages), but there is a lot of great information in there. It should answer any questions you have.
BTW, why don't you join the NY Chapter being that you are already here. Follow the link in my signature.
See you around the board!!
__________________
Darren
1999 F-350 Super Duty XLT 4x4 V10 extended cab
  #3 (permalink)
Old 11-17-2007, 05:35 PM
Hi Darren
, I have read through all the threads of the link you provided, and nowhere does anyone mention anythiong about the realy that controls the power door locks. I tell you that I need to replace it. If you, or anyone else knows where it is located, please tell me.
Thanks, Dennis
  #4 (permalink)
Old 11-17-2007, 05:43 PM
tewferford's Avatar
tewferford tewferford is offline
tewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant futuretewferford has a brilliant future
Quote:
Originally Posted by dennisg
Hi Darren
Thanks, Dennis
This may sound crazy but, did you try the autozone website. They have a online manual for locating parts on a vehicle.
__________________
Frank
I live in my own little world,but it's OK, they know me here.
Chances are,If you bought it, A truck brought it.
  #5 (permalink)
Old 11-17-2007, 05:53 PM
Hi, nothing sounds crazy, thanks for the tip, I will give it a try, and let you know.
Dennis
  #6 (permalink)
Old 11-17-2007, 06:05 PM
HI, I just look on Autozone web site, they have the realy, but do not tell you where it is in the truck. It was worth a shot, thanks for the tip.
Dennis
  #7 (permalink)
Old 11-17-2007, 06:36 PM
tewferford's Avatar
Dennis
I'm sucking beers down now but, I will look tomorrow. I'll find it for ya.
__________________
Frank
  #8 (permalink)
Old 11-17-2007, 07:09 PM
britt britt is offline
britt is starting off with a positive reputation.
Dennis i have a 00 sd v-10. i had to replace the lock actuators on my truck last year one wouldnt work at all. i changed them all out to be on safe side , you need to get the actuators from the dealer so they match up, i looked at some aftermarket actuators but they did not match up.. you need to pull the door panel off to get to it the old one snaps out you plug the new one in and plug it in. i think it is located next to the latch on the door -- match up the left side and the right side-- the switches are made for the left and right sides. hope this helps--good luck - britt
  #9 (permalink)
Old 11-17-2007, 08:58 PM
Ronin007's Avatar
Dennis - so is it the actuators or the relays that are bad?
Whenever I have heard of the SD locks not working it was due to the actuators so that was why I directed you to that thread. Sorry if it was not the correct information for you. Sounds like Frank or britt have you covered on the relays.
__________________
Darren
  #10 (permalink)
Old 11-17-2007, 10:57 PM
Dennis i ran across a topic a few minutes ago that tells how to fix your actuators yourself, i dont know how tolink you to the tread - but it is under "power door locks FIXED" hope this helps - good luck--britt
  #11 (permalink)
Old 11-18-2007, 02:28 AM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
2005 Ford F-150
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Idunthave1yet
Quote:
britt,
Post #2 (Darren's) had the link you were looking for I believe...
__________________
-Rich; SC-DPS Reserve Trooper
'05 ReCab XL Pw,pwdlk, cruise & more w/139K
Chapters / 2004-2010 F150 / 2011 F100 Moderator
  #12 (permalink)
Old 11-18-2007, 09:16 AM
Jack_99V10 Jack_99V10 is offline
Jack_99V10 is starting off with a positive reputation.
Dennis,
I would reconsider Ronin's post above for the "Power Locks Fixed" thread. Your symptoms match those in that thread and I think that if you happen to fix that problem you will see that you don't really need to swap out the relays, and then you can return them, and have working locks for free I just thought it was odd that you have the same problem as everyone else, but you want to swap out parts that are probably not necessary. Just my opinion, I hope I didn't offend you.
if it makes you feel any better, I had a 99 F250 V10 2 months ago that had the same problem, and I currently have an 00 F350 7.3 with the same problem... Fortunately for me I have 2 doors to experiment with now that I have a Crew Cab... and I might actually have time next weekend to dig into them.
Good luck with whatever route you take.
__________________
2000 F350 CC LB - 250cc 200% - Matt Tuned - 9" Lift - 38" Extreme ATs - Vegistrokin since 08/23/08
http://i2.photobucket.com/albums/y9/...ig_500x100.jpg
  #13 (permalink)
Old 11-18-2007, 04:45 PM
Thanks everyone, but shame on me for not mentioning that I already swaped out the actuators, new from the dealer. Sorry...But that being the case, the problem still is a problem. they sometimes work perfectly, like now, and for the last two days, before that they would only lock, not unlock, Etc.,Etc. I will not be happy till I find that #@#* relay.
Dennis
  #14 (permalink)
Old 11-18-2007, 05:53 PM
Ah. I see.
Very interesting...
I guess you understand why we were pushing that on your first :P
Keep us posted.
__________________
  #15 (permalink)
Old 11-18-2007, 06:20 PM
HI, Yes I do, and I thank everyone for all the "pushing", but I belive that in this case, not your easy fix. Sometimes I feel that if it was not for my bad luck, I would have no luck at all That relay has to be somewhere in the truck.
Tags
1999, 2002, a1989, actuator, door, f150, f250, ford, location, lock, power, relay, relays, thedoor, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
