My 352 has C4AE 6090G heads, why?
Old 11-13-2007, 08:07 PM
asmith6's Avatar
asmith6
asmith6 is offline
Hello all. Well I pulled off the intake manifold, rockers and pushrods. Getting ready for new cam and a 4v intake and carb. As some of you may already know I have a 65 f100 352. The motor has 140,000 miles and was rebuilt 40,000 ago. The valves look good as do the springs. My question is: the casting numbers on the cylider heads reads C4AE 6090G from what I can find these are not the original heads for the 352. The intake ports on the heads measure 2.34 tall by 1.34 wide. From what I can find these heads came off a 427 CJ motor. IS this correct? Are these good heads to have? Will these heads play a factor into cam, intake and carb choice?
Old 11-13-2007, 09:17 PM
Hypoid's Avatar
Hypoid
Hypoid is offline
They were a common production head for that year; stock size valves. The G heads do have a reputation for good flow.
Just off the top, the 427 had a H (?) suffix. I'm sure others will chime in on that.
HTH
Old 11-14-2007, 03:49 AM
FFR428's Avatar
FFR428
FFR428 is offline
Needsmorecoffee.
Yes those are good heads. And they are not from a 427 or 428CJ. They are more than likely the stock heads that came on the 352.
Old 11-14-2007, 03:56 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by FFR428
Yes those are good heads. They are more than likely the stock heads that came on the 352.
You are exactly right! C4AE-6090-G heads = 352 = 1965/67 F100/350.
For service replacement, these heads were replaced by Ford in 1968 with the 360/390 heads.
1963/65 427 cyl head casting number: C3AE-6090-J
Ford never applied the terms: Cobra Jet or Super/Cobra Jet to 427 engines.
No 428's till 1966 / No 428 CJ or S/CJ's till 1968.
Old 11-14-2007, 07:14 AM
jowilker's Avatar
jowilker
jowilker is offline
Bill, You are right, it was Carroll Shelby that caused all them grown men to get weak in the knees and drool and slobber all over themselves at the mention of 427 anything.
John
Old 11-14-2007, 08:35 AM
Redmanbob's Avatar
Redmanbob
Redmanbob is offline
Yeah that C3AE number looks real familiar, as i kick myself in the ***!!
Old 11-14-2007, 09:30 AM
asmith6's Avatar
asmith6
asmith6 is offline
Info appreciated, thanks much.
Aaron
Old 11-14-2007, 09:35 AM
stryder's Avatar
stryder
stryder is offline
Dont kick youself too hard.I just let a complete C3 390 from a T-bird slip by for $125 on Ebay last night. 70 miles from me and no easy way to go pick it up right now. I do have a lead on a '65 352 down the road. Just hoping the owner wants little for it.
Old 11-14-2007, 09:42 AM
RapidRuss's Avatar
RapidRuss
RapidRuss is offline
FE "Freakin Expensive"
Some port clean up and a little bowl work and some CJ size valve's...C4"s will flow as well as out of the box Edheads......Make sure to check your intake to your heads for ports match....and also port match your gaskets.... JMO
RJ
Old 11-14-2007, 10:36 AM
Redmanbob's Avatar
Redmanbob
Dont worry Russ once this build starts I'll be like a knat distracting you from your beer LMAO!!
Old 11-14-2007, 11:25 AM
RapidRuss's Avatar
RapidRuss
Not a Problem Bob...If I can help in anyway......I'll be more than happy too!
RJ
Old 11-14-2007, 09:14 PM
Redmanbob's Avatar
Redmanbob
Dont worry I'll spread the knagging between you and Glenn, Freight & any other sucker just enough to keep you off your marks till race day ROFLMAO!!!
Old 11-14-2007, 11:39 PM
RapidRuss's Avatar
RapidRuss
Oh Bob, you better watch about getting Larry nervous!!! He'll bring out the Wagon and spank you with it at the track.....There can be nothing so embarrassing as to have a 4 dr. wagon put your *** on the trailer !! LOL.....
I think its pretty neat!!!
RJ
Old 11-17-2007, 02:57 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
"Beemer Nut" is offline
You wish and so do I that we had those C4G heads you had ported with those high bench flow numbers of last year Russ. Someone out there is happy with 'em I bet.
Old 11-17-2007, 07:56 AM
Redmanbob's Avatar
Redmanbob
speaking of this bench flow system. Does any machinist have this or is it something you find only at Dyno houses or ? Any idea on cost to have a set tested?
Quick Reply: My 352 has C4AE 6090G heads, why?
