2002 7.3 power stroke looking to try veggie oil
hi i was considering on trying wvo i saw an add on diesle secret .com they so no conversion is needed does any one know or has any one tried to burn wvo with diesle getting to 3.50 a gal. in my town im considering this just looking for any input
check out http://www.biodieselcommunity.org and appleseed processor. it will show u how to refine it yourself. If not refined it will jell easily or plug your filter causing injector failure. there is also a seperate forum catagory based on this kind of discussion. im thinking bout building one myself. good luck
on
welcome to FTE
if you want to run strait wvo..you need a holding tank in the truck as well as some plumming..one of our sponsors has this kit. Alligator Diesel Performance .if you want to run bio diesle..just pump and go..you can find out more by going to the Bio-diesel, Propane and Alternative Diesel Engine Fuels forum and ask questions there...
A lot of people such as myself blend with veg oil. There's a lot of variables such as the vehicle and climate that you live in. One thing is for sure, you don't need the DSE stuff to do it with.
Check out some info here: http://biodiesel.infopop.cc/eve/foru...m/f/9751014871
That's a forum about nothing but blending.
A conversion on the truck to run straight veg oil is also a thought or you can run tried and true biodiesel. See what option is best for you.
onthemoveactivist
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-13-2014 12:42 AM
dzzavid
03-06-2008 08:04 AM
Orpackrat
10-14-2006 12:03 AM
