I've officially been "Stroked"
Originally Posted by BigDaddy6969
Just when I had faith in Ford that they had 6.0 cleaned up well enough to buy one this happens. I blew my first injector on the '07, only 18000 miles. Its pretty depressing really. I think I might go back to Dodge after the 1st of the year.
I'll bet that when you get your Dodge and blow an injector you will lose faith as well, I assume. Why do you give up so fast, put up a fight or something. I.E. FIX THE DAMN THING
Originally Posted by V10_Cougar
THIS BELONGS IN THE 6.0 L FORUM. LEARN YOUR FORUMS
Furthermore I am thinking maybe of going w/ either a Chevy Dmax 3500 or maybe, just MAYBE a F F350 w/ the V10.
The Chevy is #1 to expensive I think, #2 I have had HORRIBLE luck w/ Chevy's in the past and its more of a mental block to get over for me to buy one more than anything.
The F-350 is a nice truck and all but I dont know if the V10 is enough motor for what I do with my 1 tons. I pull a heavy trailer ALOT in the spring/summer, usually somewhere in the 14-17K lbs department 2 to 3 times a week. A V10 dually would probly do the trick I am thinking and cost me about 10K less than the Dmax. What do you all think?
I think you get what you pay for...no pun intended.
Why the beef with the duramax? Why is an injector such a let down? It wasn't a turbo or a completely blown motor... it's like a spark plug. Ya, it's important, but not really the end of the world and not a sign of things to come. Lb7's Duramaxes have had injector issues as have the cummin's. Are you loosing faith?
Why even consider a V10? Do you really miss the safety and reliability blanket of poor gas mileage of the V10 (I'm asuming the last truck with the V10 treated you well.) and the "no-go" compared to the diesel? There is a huge tradeoff there IMO.
You know in your heart and in your wallet what you can and will do. I am not one to jump ship esp at 18k even though it is disheartening. I would put an injector in it and drive on if it were me. If other problems come up, then I would ditch it. But right now I would stay the course.... If that helps at all?
Originally Posted by Big Bad
The 3V V10 hardly provides "no-go" compared to the 6.0L, or any current diesel for that matter.
( 3/4 ton, supercab, long box, with 2 quads on a deck on top of the box and survey gear loaded inside the box )
Do they still build the V10?
Originally Posted by DMAX-HD
Yea I wouldn't sweat an injector man. If it was re-occuring then I would be more concerned or make ford replace them all or something. But from my understanding it's kinda like day-surgery for your truck :-)
How is the new rig treatin' ya so far DMAX?
The 6.0s were known for blowing turbos, headgaskets and bolts. I don't think they were very bad on injectors. But an injector is no big deal, 1 injector goes bad at 18k, while the rest are fine. Its still under warrenty and its neglidgeable. s**t happens. Now if 5 injectors blew, both headgaskets blew out, and the turbo vains gunked up all at the same time, then I would be let down
Originally Posted by SMIGGS
I've driven quite a few 2V V10's and they performed very well in our application.
2V V10s can still be had in the E-Series.
I've driven bucket trucks (~18,000 lbs.) with both the 6.0L PowerStroke and the 3V V10, and honestly the 3V feels stronger than the 6.0L to me.
http://www.pickuptruck.com/html/2007...otout5mpg.html
http://www.pickuptruck.com/html/2007...otout7mpg.html
