F600 steering box for a '60
Originally Posted by wademo
I am still looking for an F600 steering box to fit my 1960 F250. I haven't found one in my neck of the woods yet,so any help would be appreciated.Thanks!
Will this work on a F250? I don't know.
B7Y-3504- A .. Steering Gearbox / Made by Gemmer / Housing casting number: 4CC25
Try this place: SoCal Truck Wrecking 323-587-3144 - ask for Marty
No help here on the f600 box. ND a f600 box in a f100 is like making a chevette into a caddy. The larger box makes them drive so much nicer. The only problem is they are larger and sometimes interfer with engine choices. If you look up in your books it shows a 90 degree adapter for the oil filter for the y blocks in a f600 and this is to cure the clearance problems.
Kevin Bigwin
Kevin Bigwin
on
Howdy, I just saw your post
I have the complete steering column for your 60 F 600 truck, the only one i have, I will check the Gemmer casting number 4CC25 that numberdummy gave on saturday, i dont know what it would cost to ship it, but might be easier to box up if i remove the steering wheel. if you want to call my cell # is (209)769-4058 Jess
on
steering gear, help! numberdummy
Hay numberdummy i checked the gear box that i think is for an F 600 that wademo is looking for, the Gemmer part # is GDC43 what do you make of this #??. Hay wademo! i have a few more gear boxes i will check for one to see if it has the part # 4CC25 that bill gave and let you know what i find, this GDC 43 box is a lot lot bigger than the avrage pickup gear box. maybe out of an f 700?
Jess
Jess
Originally Posted by mrcman58
Hay numberdummy i checked the gear box that i think is for an F 600 that wademo is looking for, the Gemmer part # is GDC43 what do you make of this #??Jess
C1TT-3504-G .. Steering Gear ~ 1961/63: Use with F800/1100 with Manual or P/S.
Howdy Jess......Hows things in the oil patch? (I hope i'm not thread hyjacking since it looks like this is one is wrapping up nicely)
Hey you wouldn't happen to have a 5.83/8.11:1 ring and pinion for a 2 speed out there laying around would you?(or a 2 speed for that matter)
Cheers,
Rick (formerly from the Taft oil patch!!)
Cheers,
on
2 speed rear end
Hi Rick,
your looking for the 1 1/2 or 2 ton type 2 sp rearend?? it is possible that i have it, 5.83/8.11:1... are you looking for just the pumpkin or the whole rearend?
out of the 7 rearends that i have spare 1 might be what you are looking for.
I will check them out over the long weekend, (209) 769-4058
thanks. Jess
thanks. Jess
Steve
07-07-2014 08:27 AM
michaelshewkin
13
01-11-2014 10:54 PM
dmynatt
03-05-2009 09:20 PM
