You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
1) if the S-charger belt breaks..... will the engine still get me home?
Yes, without any problems. It'll just be slow as molasses!
Quote:
2) Is the auto/transmission good, it doesn't have any leaks or slippage right now?
The 4R100 in the Gen 2 Lightnings are tough cookies. They have the same internals the PSD 4R100's have.
Quote:
3) Is the ring/pinion harder than usual to change because it has a 4.11 now and I'd Reuther have a higher gear in the low 3's
What makes you think it has 4.11's? If anything it'd be 4.10's (pretty sure someone wouldn't change it to a 4.56) but it wouldn't be 4.11's. Ford doesn't offer a 4.11 gear for the 9.75 rear end. I'm pretty sure there isn't an aftermarket R & P gear available in that size too, but I could be wrong.
I guess I should ask, why do you think the gear has been changed from the OEM 3.55's?
Stewart
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
