is it cheaper by a long shot than Motorcraft 5W-20 semi-synthetic at walmart? That's almost as cheap as a lot of standard oils.
That's good, because the motorcraft oil is just Phillips 66. I believe Phillips 66 is a fine oil, but you pay for that Motorcraft name. I see Phillips 66 regularly about $2.69/qt. Motorcraft is always higher than that. Wolf's Head and/or Amalie is some of the very best oil on the market. I'd say you can't go wrong with either.
