1989 F150 Transmission Help
Hi everyone,
I recently purchased a 1989 2WD F150 that has transmission problems, the previous owner gave up on fixing it.
The problem is that the one in the truck and the spare trans he gave me are not the right ones for the truck and he did not have the original anymore.
My question is ...Is there any way to find out what the original trans is, maybe by the VIN???
I already tried the local dealer with the VIN, but, the only help they gave me that maybe the right trans tag # should start with "E9TP" and that the rear housing should measure either 10 and 1/4 inches or 11 and 1/4 inches.
Any body have any sugestions, web sites with diagrams, or one I could use the VIN on???? Anything would be a great help.
I need a starting point in order to find/locate the right trans.
Thanks
giorno
Thanks
giorno
Post back what is under the TRANS on the sticker on the door.
Here is a link to the sticker.
http://i54.photobucket.com/albums/g9...rd/IDLabel.gif
I gave both of the tag #s to the dealer and they said neither was for my truck.
The on ein it now only goes in reverse and 1st gear, it won't shift to 2nd, 3rd, or OD.
And the wiring harness only has one plug in the tranny for the neutral safety switch, there is another plug just haning out by the tranny. Also the mechanical speedometer cable it just hanging there with no were to put it in the housing. This is the
The other tranny has the 11 and 1/4 hoousing with a hole for the speedo, and neutral safety switch but no spot for the other plug on the harness.
Also both tranny's linkage seem to be at the wrong angle or length for the throttle vavle kickdown cable.
Thanks for your help.
Hope this helps
giorno
Hope this helps
giorno
Well the one that is in now sounds like a 4R70W transmission or some PCM computer controlled transmission.
On the "other" transmission I am not sure what you mean about the plug on the harness.
You need just a plane old AOD transmission out a late 80s F150 2WD Truck with the same wheelbase and engine 302/351.
The wrong angle sounds like they may be out of a Van.
I just replace the trany in my 1989 F150.
Cost me just under $300 CDN to get a used one from the wreckers.
It seems to work great.
From everything that you wrote and what the other guys are saying you should have the same trany as mine.I am positive the EPTP is even the same.
Mine is an AOD trany with a 10 1/4 ext.
This is for a F150 (302) 2WD.
The shifter may give some further indication.
Mine shows P R N (D) D 1.
Hope this helps
Andy
Hope this helps
Andy
That is a great help and it is appreciated.
My truck sounds identical to yours.
But,
I do have a couple of questions...
Does your tranny only have the neutral safety switch plud and mechanical odometer or does also have another plug coming from the wiring harness, maybe for some other sensor???
Also does anyone know any differences between an AOD and an AODE-W tranny???
Doe the AODE-W have that extra plug or am I reading to much into this.
I just want to get the right one the 1st time.
Thanks
giorno
But,
Thanks
giorno
