Creating a real tough truck?
Looking at a 94 F-450 7.3 IDI turbo with 130k 2wd e4od used for towing horse trailer. Is there anything I should look for?
They only thing I don't like is that the truck doesn't have power windows/locks and it's not 4x4. I can get a 93 F250 xlt 4x4 7.3 diesel for a $1000 but it reverse is blown. I'm hoping to switch the powerwindows/locks and a/c system cause the 450s is broken. That should work???
Other than that looking at swaping in the 250s front setup for 4x4. Is this 100% bolt up swap, whats involved, can it be done, will it weaken my front end????
Do the usual stuff...Check for rust. Check all the fluids. Check the tires, rims, brakes, air filter, P/S fluid, tranny fluid. Pull the intake hoses and check the turbo fins. Check the batteries.
Hit the body panels with the palm of your hand. Give 'em a good smack, but don't dent them. If you hear sounds like something is falling inside the panels, walk away. That sound is most likely pieces of rust breaking loose from the inside.
Someone had a link with an awesome list of things to check before buying a used truck. I can't find it. Hopefully, someone will post it again. If (When) they do, I'm bookmarking it this time.
Originally Posted by wreckit72
Here you go IDMooseMan. http://pages.prodigy.net/stevebaz/_import/pages.prodigy.net/stevebaz/index3.html
