Thanks for the good work, I got 2 of your corners and have one in and it fit good, the other will only be a partial. I find it hard to keep going on a regular basis and winter will be here soon, I want to have all the welding done on the cab, blast it and epoxy prime it before it gets cold, yes it does get cold in Canada.
One question, I got some shrinkage on part of my weld, what can I use to dolly it with as the weld is down inside the corner. Anyone else have this problem.
wgc
Since my Panel doesn't have cab cornors I don't know how tight it is. What you're looking for is something that will transfer the impact of the hammer. Heavier is better.
I've use other hammers, rocks, pipe, wood blocks, and once a sock full of wet sand.
Hope this will get the gears turning.
