key pad code/OEM security
Anyway to find out the master code for the key pads on the door??? I bought the truck about a month ago, 04 F-350, but no info on the code for the key pad. I know there is a master code that can not be erased, and then you can program your own code. Dealer wants $300 to 'find' the code for me......I told them my key works just fine for now to open the door!!
There is also a FORD security system on the truck. Under the fuse panel cover, there is this seperate black box, labeled from FORD, with a harness connecting to verious other wires..does look OEM, and not cut/splice. On the box it lists color codes for the wires, such as door lock, ignition cut off, flashers..etc.. If I unplug this box, the truck will not start/turn over. There is also an led light, typical for an alarm. Anyone know what I gotta do to use this alarm? What kinda key fob Ill need and what not?? The only key fob I have now is the basic keyless entry...lock/unlock/panic. Any help would be appreciatd
TIA
TIA
I don't think there is a universal master code to open any truck door. If I'm not mistaken Ford has to send off the research the VIN & send off a request to the keypad manufacturer to get the master code for your truck. The keypad mfg charges Ford, who marks it up and charges you.
On the bright side you probably have a better chance of figuring out the code by just punching buttons than you have of winning the lottery. Just make sure if you get lucky you remember which numbers you hit.
On my F250, i found the code by removing the plastic panel at the lower center portion of the dash(2 screws). The part that has a hook on it for a garbage bag or what not. After removing the panel, I looked straight up through the hole, toward the mirror, and found a box with a factory sticker on it with a 5-digit code. The 5-digit code was the largest text on the sticker. I searched the internet for about 3 hours trying to find this info. Hopefully your 04 is the same as my 05.
Originally Posted by F350-6
I don't think there is a universal master code to open any truck door. .
Im sure someone can confirm this for me!
Paul98038
1997 - 2003 F150
12-31-2019 03:57 PM
AZ_Mike
10-23-2016 04:36 PM
