Turbos: better bang for the buck
Im looking to put a turbo on my new to me 89 f-250 7.3 N/A and ive been trying to decide which will give me the best results for the price? i would appreciate any thoughts or comments since this upgrade will cost almost as much as i paid for the truck! i dont want to pick the crappy 1.
THanks in advance guys!
the motor etc has 107k on it i bought it with 105k from the original owner, an elderly man who only even used it with a camper on the back. oil was changed every 2-3 thousand (i found all the reciepts in the glove box) recently had glow plugs, alt, and starter replaced. i dont believe its tired, but this is my first diesel. what are everyones thoughts. should i go for it or not?
thanks guys
keith
thanks guys
keith
if it were me 'd go for it. even if you do break the moter or something in there its allways possible to replace of fix it. mine has 250,000+ and it has never had an engine problem whatsoever. -it still hasn't even had the injectors replaced-
and i gotta say for my first car that wasn't dumptruck. i like it a lot
Keith, If you want the added power, it's a great way to go it you have the money and time. It's recommended because it really does unleash the motors potential..... but were all kind of biased on the forum. You'll get sucked in and get a new injection pump, DPS stage 1 injectors, water/methanol and propane injection, head studs and cranking up the boost to the high teens. But ultimately it's your call and sure it's OK and fun to spend your money.
There are many posts regarding both systems, both seem pretty good.
Ram air should be on your short list.
i had another thought after i made the call to banks and found out the kit price of $2900 and figuring int my other expenses realize i cant afford it right now
i was wondering would it be possible to go to a yard and pull a turbo off a volkswagon or something could i possibly hook that up? i figure i wont have the same amount of boost or anything but maybe i could get some kind of gain form it? maybe there are a few low-buck mods available or tweaks i can do with what i have already?
thanks guys,
keith
thanks guys,
keith
Received 3,108 Likes
on
class 8 truck engines usually run in the 30-40 lb of boost range. putting a turbo like that on an IDI engine would blow the heads off it. anything over 15 lbs of boost on a stock IDI is asking for trouble like catastrophic engine failure. that is why the aftermarket turbo guys limit boost to under 10 lbs.
