Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 08-31-2007, 08:45 PM
Silverrv Silverrv is offline
Garage is empty, add now
Silverrv is starting off with a positive reputation.
Question injector problems
I have just started to check out the problems I might have with this new fuel. I run a 7.3 PS 2002. Has anyone had trouble with the new fuel and injectors. I was told it didn't lub the injectors as well and caused them to fail.
Someone said to add a little trane oil to the fuel helped.. ??
Whats the true story.
__________________
2002 F250 SD 7.3 PSD Lariat 4X4 Off Road Crew Cab, Diablo Predator
2005 F350 SD 6.0 PSD Super Cab Duely
  #2 (permalink)
Old 09-01-2007, 01:08 AM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
15ppm #2? You shouldn't notice much of a difference between it and the old stuff. It's supposed to have lubricity additives to make up for the lost sulfur.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #3 (permalink)
Old 09-01-2007, 01:45 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
If you want to be safe add Diesel Kleen or Stanadyne to your fuel.
Buy DK at Walmart.
Better yet run BioDiesel. almost any blend will get adequate lubricity
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #4 (permalink)
Old 09-02-2007, 07:05 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Cookie, when I was running across the country I really truly could hear the difference in the fuel on my engine. It may have been the different areas of the country and how the fuel is treated for weather or maybe quality. But I will say that I listened to a number of conversations on the CB about complaints in that area.
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #5 (permalink)
Old 09-02-2007, 08:26 PM
firemediceric's Avatar
firemediceric firemediceric is offline
firemediceric is starting off with a positive reputation.
When I have to burn #2 diesel, I add 1 ounce of 2 cycle oil per gallon of fuel.
FWIW, after reading the MSDS, I think Diesel Kleen is worthless for lubrication.
I wish I could give you a link to MoparMans 2 cycle oil web page, but I read that big oil has forced his web site to close down. Do a Google search on MoparMan and you may be able to find threads in other forums as well as here discussing the use of 2 cycle oil as an additive for ULSD
__________________
1999 F-350 with Tymar type air filter, Dahl 100 fuel filter, HP oil X-over, bypass oil filter, coolant filter.
Tags
f350, injector, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
