Tow/Haul Mode - On or Off
I was curious if most FTE members with the 6.0l actually use the tow/haul mode when pulling a load. Please let me know if you do and what type of load WT that you usually tow.
I have towed our travel trailer (8800lbs apx) twice now. I used the tow/haul mode on it the first trip but didn't on the second. The only real difference I could tell was when I was going down hill. (I used the brakes a lot less with it on). It seemed like the uphill was very little or no different.
8k# +
When towing my toy hauler, it's 8000+ lbs when wet and full. I would NEVER think of not using tow/haul with that thing pushing me down the hill! As for going up the hill or on flat ground, T/H mode holds the correct gear... No gear hunting or early shifts. When running empty, I have used it often. Stop-and-go SoCal freeway traffic, just slow cruzin' on dirt, etc... The T/H can also make your 9000 lb truck stop on a dime, where it may have otherwise taken 15 cents. I know it has saved me once, so I've got my finger at the ready when a panic braking situation may arise.
Thanks for the quick replies, Were headed over the coast range with the trailer again this weekend so I'll be sure to use it.
Does anyone see any long term issues using it all the time? It seems to me that with the 6.0, working the engine is not always such a bad thing.
Also I know driving empty with the Tow/Haul switched on it makes the shift points much higher. This may be a better set up for the engine but probably worse for the tranny? What do you think?
Agree. I use is anytime I tow and sometimes when empty. I initially had some mis-givings also. It seemed much less predictiable as to when it would shift. But after using it for a while, I have found that it is very predictiable, just different. The T/H mode really keeps the engine in its peak range, which is what the transmission is supposed to do anyway.... my 2cents with change back.
The tranny was built for the tow/haul mode. Do not be afraid to use it with or without the trailer! I just got back from a 10, 450 miles X-country trip with my 30' 5th wheel. I love that tow command combined with the tow/haul feature!! Talk about saving your brake pads in the mountains!! WOW!
And personally, I hate soft shift points. I'd just as soon my neck gets snapped a little when from a nice, firm shift. If I had wanted soft shifting, I would have bought a car.
I love the Tow/Haul on my '03 6.0. Whether with the 3000+ truck camper, the 6000 lb trailer (and about to start doing them both at once, just haven't had a race since I got the truck camper).
I agree, it makes the engine WORK, which is exactly what the PSD wants. They seem to get pissy if you don't work them, and this is just another way to get it to work. That and towing in itself.
HTH
HTH
