F150 Triton V8 big problem
Old 07-24-2007, 09:38 PM
glassgenie's Avatar
glassgenie
glassgenie is offline
Has anyone ever heard of the guides and tensioners going out on a 2001 F 150
Triton V8 4.6 with only 69K on it. My truck started making a knocking noise a couple of weeks ago and didn't think too much about it. Thought perhaps it needed a tune up or something. Anyway, I took it into the dealer and was told the guides and tensioner, and timing belt? were broke, plus something about a gasket. I am still in shock and didn't write it down when the dealer called. cost is 1800 dollars. I just got this paid for, bought it new, extended warranty ran out 4wks ago, just my luck. I could understand if it had 180K on it, but not 69K.
I donl't know alot about engines, but everyone I have talked to said they can't believe that it happened with such low mileage. I Don't haul heavy stuff or pull heavy loads, I keep it serviced. Is there a re call or anything on something like this. It was running fine and them BAM! starting that knocking noise. Thanks for any comments or suggestions in advance.
glassgenie
Old 07-24-2007, 10:45 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
I've heard about it rarely but never with that kind of low mileage, if the dealer was decent they should share some of the cost being that close to the warranty IMO. That is IF it was a Ford extended warranty. For another $1800 you could just get a new engine, an option worth considering to me. Also if it was running the timing chain obviously isn't broken, but if it was running very long with the tensioners broken it probably ate it up pretty good.
Old 07-24-2007, 11:16 PM
glassgenie's Avatar
glassgenie
Thank you for your comments. I bought the extented warranty when I bought the trk thru the dealership. I thinks it is a UPSC? All my papers are in my glove compartment at the dealership. It is hard enough for me to come up with the 1800 much less 3600. It was still running, drove to the dealership. Guess something got ate up like you said. Been reading a lot of forums, there are some bad things posted about ford on some of them. I have always liked ford. But now I am afraid if this happened at 69K what is going to happen next.
Old 08-02-2007, 09:44 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I've heard of tensioners and guides starting to make noise in the modulars. Around the 200K+ mile mark
The only way it would happen is if the oil wasn't changed for long periods of time.
Old 08-03-2007, 09:35 AM
glassgenie's Avatar
glassgenie
I had the oil changed regularly. Called Ford and they said they couldn't do anything. anyway got it repaired 1800.00. Hard pill to swallow. Thanks for your reply.
glassgenie
Old 08-03-2007, 01:52 PM
94yj's Avatar
94yj
94yj is offline
never get and aftermarket warranty they are not worth the money
Old 08-04-2007, 08:36 PM
bigblock_drock's Avatar
bigblock_drock
bigblock_drock is offline
i no there were recals for the 4.6's in the crown victorias but not sure if its the same guides as the 150's
make sure the dealership check and cleaned the oil pickup tube b/c there may be teflon from the timing chain guides that got sucked up, especialy since u kept driving it
wolgie
181
05-24-2021 10:23 AM
66 bronco roadster
1999 to 2016 Super Duty
28
04-21-2016 10:28 PM
MarksA-C
2004 - 2008 F150
05-17-2012 11:32 PM
Quick Reply: F150 Triton V8 big problem
