Warning Light 01 Ford Escape Cooling System
The coolant light on 01 Escapes is notorious for failing. It is most likely the sender switch located in the coolant tank itself. If the fluid level is okay, but the light is on, that's a pretty good indication of the bad sender switch. The 2 fixes I know of...either replace the coolant tank (switch is embedded in it), or unplug it at the coolant tank. I replaced my tank a couple of years ago and the dash warning light has never come back on.
My '03 did the same. The first time the reservoir was cracked.. the sensor and resy are 1 unit... Cost me about $280 to replace from the dealer.
The second time the light came on the resy was full... I added about .5 liters of bottled water and the light went off. The sensors are very sensitive to very small level changes...
Best -Coop
Best -Coop
raytasch
Escape & Escape Hybrid
05-01-2015 08:20 PM
