Need Help!!
Need Help!!
This is a stupid question and i probably won't get anything from it but here goes: I have a Fabtech lift (see sig) and one of the cam bolts has broken off, i found out when having the local shop do an allignment, they found a bolt that would fit the spot but it isn't a permanent solution.
I called the place where i ordered the kit and they could only sell me a pack of 4 of the bolts and it would cost me $87 not including shipping.
I really don't want to spend $100 on a bolt, sooooo.... does anyone know where i could get one??? or maybe someone has a spare one in their back pocket or something? I would appreciate any and all help on this. Thanks!!
EDIT: part # is FT<!-- -->F 292 if that helps
Sorry I don't have a bolt. My two suggestions would be:
1) Call Fabtec directly and let them know a piece of their kit broke and you aren't happy about it. (be polite) but see if they would be willing to send a free or low cost replacement. I don't know for sure, but if it is the bolt I am thinking of, a broken bolt could lead to catastrophic failure? This might be another angle to push with them.
2) If all else fails, see if a local machinist might be able to hook you up. We're basically talking about a bolt with an eccentric washer, and you already have the bolt, so they might be able to make the washer part pretty cheap.
Good Luck
Good Luck
Good Luck
Good Luck
