bleeding brakes
Bleeding is always farthest first. Souder's post would be correct.
Brake fluid is under virtually no pressure unless you press on them and then it is very high. Never open the bleeder when under pressure. It'll just spray all over and usually into your face. Only open it, THEN press the brake, hold it down, close the bleeder, let off the brake.
Hobdy
36
04-22-2019 04:44 PM
aidandj
08-26-2013 03:35 PM
jcarrick
17
04-10-2013 06:00 PM
