Go Back   Ford Truck Enthusiasts Forums > Diesel > 2008 - 2009 6.4L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #46 (permalink)
Old 07-13-2007, 05:56 PM
PSD6litre40's Avatar
PSD6litre40 is starting off with a positive reputation.
Quote:
Originally Posted by freekyFX4
And if Hillary wins, there's no telling what might happen!
I know i'm moving to Canada or somewhere if that happens!
__________________
- John
2008 F-250 CC Lariat Black 4x4 w/ 20's (33000 Miles so far)
Mods so far:
- 4" Cherry Bomb/Flo-Pro Duals
- Custom DOC/DPF Delete Pipe
- Spartan Phalanx w/ 250HP Tune
- S&B Intake
- Billet Fender Vent Inserts
- Toyo 35" Open Country M/T
- 2.5" Donahoe Racing Lift Kit
Sponsored Links
To remove this ad, register today!
  #47 (permalink)
Old 07-13-2007, 07:05 PM
kimminau2 is starting off with a positive reputation.
Canada might not be far enough!
__________________
2008 F450 King Ranch, 4.88's and everything except rear DVD.
2006 F250 King Ranch V-10, 4.56 gears, 46 gal transferflow tank, 2-1/2" DR lift, 35" Procomp extreme AT tires, SCT tuner, Firestone Ride-Rite air bags.
2000 Excursion 4x4 V-10
2007 Expedition EL, Eddie Bauer, loaded.
  #48 (permalink)
Old 07-13-2007, 10:21 PM
Hanging_Heels is starting off with a positive reputation.
Quote:
PS - Apparently you feel the same way I do about the tree-hugging hippy liberals running this country at the moment. I am just as adamate about the possible ban on weapons that may find it's way through Congress soon. And if Hillary wins, there's no telling what might happen!
BEST COMMENT i have heard in a long time!! hahahahaha Glad were on the same level, right there with ya brotha....
  #49 (permalink)
Old 07-14-2007, 12:07 AM
UGA33's Avatar
Yeah Come On!
UGA33 is gaining momentum as a positive member of FTE.
To me you have to pick your poison. You remove the DPF and gain mileage saving diesel in the process. They sling the dpf's under these trucks to clean the air then they end up burning more diesel in the process.
__________________
2006 F-250 Lariat Crew Cab Shortbed FX4
-Josh-
*6.0L PSD*MBRP Turbo-back*35" BFG Mud Terr. KM2's*Leveling Kit w/ Daystar Coil Spacers & Rancho RS5000's*Spartanized SCT X3*Autometer EGT & Tranny guages*Coolant Filter*CCV Reroute*F-350 blocks*High Idle Mod
  #50 (permalink)
Old 07-14-2007, 12:24 AM
origcharger is gaining momentum as a positive member of FTE.
Although I doubt that they can actually do it, Ford has said that they will not honor warranty repairs if the exhaust is altered.
Some Ford tech. may correct me if I am wrong but when your truck goes in for a possible warranty situation they don't just throw parts and labor at it till its fixed and bill Ford. They have to follow a diagnostic flow chart, so if the readings from the sensors at the DPF are out of wack because its no longer there or been tampered with, it basically can't be a warrantied repair because its impossible to diagnose it to Fords satisfaction.
__________________
Powerstroking Seven T444Es, one VT365 and one 6.0. Also four DT466s, one DT360 and a Mercedes MBE906.
I'm doing my part to reduce food imports, control rising food costs and help feed the children, my trucks run on 100% petroleum diesel. What are you doing?
  #51 (permalink)
Old 07-14-2007, 08:45 AM
Well, I know for a fact that most of the dealers in my area do NOT have well trained techs. I am going through a similar situation right now on my 6.0 on cold starts it has a injector spool valve thats sticking for about 5 minutes. The truck vibrates and shakes and wont pull out of its own way. So, theyre fix is a reflash which did nothing I get a call that my trucks fixed and I asked what was wrong and they said they flashed the PCM and the truck is fine now. Well, the next morning sure enough still does it (this was wednesday) So I called the Service Advisor (whom is a good friend) and said the truck is still doing the same thing. He was furious when I told him this I said there is no way you could miss what this thing is going its not rocket science. The tech told him after it was reflashed he let it sit overnight and the next morning it was perfect which there is no way. What happened im sure was the truck was reflashed and sent on its way by the tech. This is why there are trucks with reoccuring problems all over the US, they throw something at it because they don't know what they are doing and wish it the best of luck. I cannot complain about my dealer, because they treat me well, but this tech needs a kick in the pants.
__________________
- John
Mods so far:
- S&B Intake
  #52 (permalink)
Old 07-16-2007, 02:09 PM
SANDDEMON08's Avatar
FORD POWERSTROKE JUNKY
SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.
Quote:
Originally Posted by SuperchipsMike
True statement!
Before and after dyno runs showed that removing the dpf gained only 1RWHP on our stock untuned 6.4L.
I would proably agree with the fact of the small hourse power gain between a dyno run with a clean DPF and without a DPF at all, but the DPF is a self cleaning filter. The pcm reads the pressures which trigger's the regen cycle. How much hp is lost when the DPF is lets say 80% pluged?
My truck has gone into a regen cycle while pulling a grade with a load, and it sucks, the boost cuts back to around 25PSI + or -.
So my point, i think the actual potentional hp loss is much higher than 1hp with the DPF.
Just my .02
__________________
Got beer ? 498HP 965
2008 F350 SD CC FX4 ON 20's, 6.4 PSD,TORQ-SHIFT,3.73 REARS, NAV, BLACK LEATHER SEATS,DASH DAQ GAUGES, AFE STAGE II INTAKE,SPEARCO INTERCOOLER,CUSTOM TUNING, SEIC MOD,AMP REASEARCH STEPS, LINE-X SPRAY IN BED LINER, T-REX BILLET SIDE VENTS.
  #53 (permalink)
Old 07-16-2007, 07:47 PM
glasseater is starting off with a positive reputation.
why don't people realize that the dpf does nothing to help stop pollution... it saves the soot till it burns it off when nobody sees it (aka when not in emmissions testing)... all that crap is still floating up into our atmosphere, and we're waisting more diesel to pollute the same amount... seems pointless... i say let the coal roll!!!!
__________________
1997 ford f350
dual 5x36" angle cut MBRP stacks
34's at the moment
3" downpipe
tymar intake
gauges
BTS valve body
stage II injectors
intercooler
twildman chip
14.06@93.8
http://s21.photobucket.com/albums/b295/250xRida/truck/
  #54 (permalink)
Old 07-16-2007, 10:49 PM
NS F250's Avatar
NS F250 is starting off with a positive reputation.
Quote:
I'm no expert, but I always thought soot was heavy enough to settle to the ground. Does soot go in to the atmoshere? Maybe Algore will chime in. My opinion is all this dpf and other stuff does is make the tree huggers feel good, thats why we're stuck with it. Kinda like 10% ethanol gasoline, you use more of it with worse mpg, but hey we're burning less oil. Just wait till they decide that we don't need trucks this big and we all have to drive a prius to save the whales, er a earth, what ever it is we're saving these days.
__________________
02 F250 CC 7.3 4X4 XLT 6637, 203* Stat, Coolant Filter
03 E350 7.3
79 F250 4X4 460 Dana 60's
68 Charger R/T
  #55 (permalink)
Old 07-16-2007, 11:04 PM
Big Sky Rancher's Avatar
Big Sky Rancher is starting off with a positive reputation.
I'll tell you a good reason for removing that new fangled emmisions crap that hasn't been mentioned yet; to prevent grass fires. Diesels have historically been better ranch trucks in the west because they don't have catalytic converters that CAN get hot enough to start grass fires.
And I'm not talking about flaming tailpipes, just the high heat from the converter/collector.
  #56 (permalink)
Old 07-16-2007, 11:12 PM
SouthTexasDiesel is starting off with a positive reputation.
This is the exact reason I do not drive my 6.4 around my ranch. It's covered in 3 ft. grass right now and will light up like a match is that thing goes into regen. Good news is that there are tuners being made that will kill the regen cycle completly so you can put a strait pipe on without worrying about constant regen. Yea I want the sound and smoke, but I really don't want the heat. Can't wait to rip it off. Here's to second hand smoke!!
__________________
08 F-350 Cowboy Edition 6.4 4x4 CC DRW 6-speed w/3.73 gears
Programmed with SCT LiveWire with DPF delete tune
Full 5" DPF & Cat delete pipe from Bay Area Diesel
6" Aussie stacks painted black
Random other goodies
  #57 (permalink)
Old 07-16-2007, 11:45 PM
Quote:
__________________
1997 ford f350
34's at the moment
3" downpipe
tymar intake
gauges
BTS valve body
stage II injectors
intercooler
twildman chip
14.06@93.8
  #58 (permalink)
Old 07-16-2007, 11:46 PM
NS F250's Avatar
So, I wonder how many fires these new diesels will cause. Hmmm, I bet there's a lot of green house gasses from a forrest fire. Kind of ironic, these trucks may actually pollute more than the old ones.
__________________
03 E350 7.3
68 Charger R/T
  #59 (permalink)
Old 07-16-2007, 11:51 PM
Quote:
'68 charger huh? i like
__________________
1997 ford f350
34's at the moment
3" downpipe
tymar intake
gauges
BTS valve body
stage II injectors
intercooler
twildman chip
14.06@93.8
  #60 (permalink)
Old 07-17-2007, 12:04 AM
NS F250's Avatar
Yeah, it's a factory 440 car, the sad thing is there are diesel guys on this site with trucks that are faster than my car.
__________________
03 E350 7.3
68 Charger R/T
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
