'94.5-'97psd V/s '99-'03psd???
I am looking at/for a super nice f350 2wd dually crew cab dually with a PSD.
I raelly want to stay with the older body style but I am open to up to 1999.
What are the differences, both good and bad on the '94.5-'97 V/S 1999-2003s?? also, did Ford NOT make a Diesel engined truck in 1998??
Guys, Hey, Thanks for the replies and info!! So the intercooler helps make more power?? I think our brand new '06 PT Cruiser GT (with turbo) has an intercooler....must be some reason it makes 230 hp!!
Seriously though are the '99 up "better" in most ways?? how about the automatic transmissions?? are they better right out of the box?? I am looking very closely at a '99 F350 CC Dually close to me with just 69k original miles.
I really know very little about Diesels so what should/could I look for/at when I go to look at this one?? Thanks Again!!
on
this is a good write up on what to look for buying a new truck
https://www.ford-trucks.com/forums/5...questions.html
in 99 they made an early and a late 99..any thing built before 12/98 has smaller inj. smaller turbo and a smaller HPOP..its still a good truck..but late 99 were a bit better..i up graded my turbo to a late 99 and see cooler exhaust temps..i want to do the inj and HPOP next...ive been told thats where i will feel the better power...the late 99 were much easer and cheaper to mod..but a good early 99 was a good truck as well...
Ive heard its a little better if u look for a later model 99 becuase it came with a larger turbo , but im not sure when exactly they started manufacturing them im sure someone else knows ... but i can tell you there is nothing wrong with the early model 99 as i have one myself but if i would of known in the begining i might have decided to go the later model one
on
the turbo on the right is the early 99..the left is a stock later year
this is the spider pipe ..where the turbo push the air though the IC and back down into the motor..you can see the early 99 on the right..the funnel looking tube sticking up gets smaller at the bottom..the later 99 it stays a full 3 inch..also at the bottom of the spider you see the 2 tubes that pushes air into the motor as a lot smaller then the later year..
Any 7.3 is a good truck. The OBS PSD as said lacks a bigger HPOP, turbo, injectors and it lacks an intercooler. All these things are interchangeable through the years so if you like the OBS then buy it and add the NBS equipment. Or buy the NBS 7.3 with all the goodies. Either way they're both great trucks!
Cowboy Steve
Cowboy Steve
on
Originally Posted by 99SevenPoint3
Well Ron's power stroke says it best ... Sorry about the double post guys ... its a good thing to remember that those things can be changed out to the bigger and better ones ...
you can get a conversion kit to upgade to a late 99 here http://www.dieselsite.com/index.asp?...ROD&ProdID=276
comes with every thing but the turbo...i got my set up from a fellow FTE'r off of an 01...but the biggest power gain is in the HPOP and the injectors...
