So what do I do now??
One thing I forgot about regarding automotive A/C systems is the fan clutch.
This is a device hooked to the radiator fan that allows the fan to 'freewheel' when more air is coming thru the radiator than the fan would otherwise be pulling thru, for instance when you are going down the freeway.
The clutch is controlled by ambient temperature, and as it warms up, it locks up. when it cools off it freewheels.
So when the vehicle is standing still and underhood temps begin to rise, the clutch will(should) lock up, pulling as much air as possible thru the radiator.
This is what causes that roaring sound of air when you first pull out of your driveway, then the sound slowly subsides as you drive along.
When I worked on automibiles for a living and suspected a faulty fan clutch I would put on a good thick glove and try to stop the fan with my hand while the engine was running, and at operating temperature. If the fan stopped easily, the clutch was defective. if, on the other hand the fan shredded my glove and trimmed my fingernails, it was okay.
(Kids, don't try this at home. and if you do, make sure you know which way the fan is spinning. cause if you stick your hand in the wrong side you WILL lose more than one fingernail)
Seriously, if the fan clutch is good, the engine warm with the A/C running you should not be able to stop the fan in this manner without enduring at least a minimal amount of pain. if you can stop the fan, get a new clutch.
Probably a safer way and one that I would recommend is to check it after the engine has been running for a while, and say you stop for gas. Put the gas in, run in and pay and when you come out, pop the hood and see how easily the fan blade spins. (this gives the clutch time to soak up some heat).
It should spin, but you should feel a good deal of resistance. If it spins easily and the temperature under the hood is like opening an oven door on Thanksgiving day, you have a problem.
Also, if you have electric fans disregard everything you just read.
BTW: Still got all my fingers!
I do have a backbone!! That's why i do not take no for an answer. And now the dealer calls me yesterday to tell me that they have found a problem with 2007 expeditions and to bring it in and they will get it taken care of right away. The reason the other dealer said they will not look at it is because I had contacted Ford direct to voice my concerns with this vehicle and was told that no further service calls for this same problem would be approved. So the other dealer said he could not look at it without charging me. And why should I have to pay out of pocket when there is less than 3000 miles on it. The deal is that several owners have been complaining and as we know 1 persons complaint does not matter.
Thanks for all of your guys advice. I will keep you updated to let you know if the fix worked out.
Originally Posted by Monsta
A bit uncalled for.
Originally Posted by zarlingo
That's what I think!! But they insist that they have checked against other expeditions and they all do the same thing. I doubt Ford will pay to have another check by another dealer. They told me that nothing is wrong with the vehicle.
Maybe I will call another Ford dealership and get their opinion.
Not to be sexist or anything but I think you should have you husband go down or make the call.
If you're dealing with dealers who have attitudes that would say the quote above, then I'm sure they are still from the era that would give a female the run around. Sad that stuff still happens...
Originally Posted by poppie
I stated the same thing in a diffrent way,I said to also have her husband take the service manager for a ride and SHOW him the issue,they were picking up on her weakness and blowing her off,having the service manager with him/her MIGHT have gotten a ,sorry your having this issue,can't figure out what's wrong at this time but will dig into it deeper and will get with FMC to get this fixed to your satisfaction while he wipe's OFF HIS forehead!!!.
My wife has been complaining yesterday again about the A/C not blowing cold at idle & low speed, and that our old van (1997 Safari/Astro) cooled down much faster. I looked under the hood a little bit while I was installing the tow package relay and I saw that there is an electrical device on the fan clutch. I've heard of electric fan clutches, and if this is what it is and not some type of sensor, perhaps its not engaging at idle if there's not enough air flow through the a/c condensor to keep blowing cool. Assuming its controled by the computer, perhaps the fix is to reflash it to engage with the A/C on. I'm just guessing here, because it cools down quite well at highway speeds.
Did the dealer happen to mention what the problem was with the 2007 Expeditions? I asked my service manager about 1 week ago inperson if there were any issues or recall and was told there was not. I know dealers don't always tell the truth, but I would think a dealer would WANT to perform warrenty work for the income. Does your vehicle have the tow package? The only reason I ask is because with the larger transmission cooler in the very front, it very well could radiate even more heat and block more free flowing air through the A/C condensor.
I asked in another tread if anyone knows what the Ford A/C test specification is. When I had the Factory Service manuals for my old Safari/Astro and there was a specific test to determine if the A/C was performing properly or not. From memory the the A/C was supposed to blow so many degrees below the outside ambient temperature within a certain number of minutes. I'm sure Ford has a similar test procedure that the dealer can follow and anyone could follow on their own to see if the A/C is up to the Ford spec. I don't have access to the Expedition factory service manuals, but the dealer should. I would ask to see what this test is and go from there.
#28
My sister in law has a 2007 Expedition (regular length so less interior volume) and said once it got hot, her A/C stopped working very good unless she's driving at a pretty good speed. She even lets her car run for a while in the garage (door open) and it still doesn't cool off very good. She just lives down the street so our vehicles see the same temperatures. Mind you its been 107-115F lately in Phoenix, but these should still cool down better then they do. I wonder what changed in the A/C or cooling system between the 2006 & 2007. Oh, she has the HD tow package too.
#29
with the vehicle idling, by setting the A/C system in MAX, (RECIRC) mode and running the fan on the 2nd fan speed, this should duplicate how the system will function going down the highway at 60-65mph with the fan on high speed.
keep in mind, we are looking at the temperature of the air in this test, not the volume.
so, for purposes of this test if the outdoor temperature is 85 degrees and you see 45 degree air coming out the vent, the system is functioning properly.
I've tested this theory countless times in the past and it has never failed me.
#30
Thanks for the advice. I'm now wondering if the A/C compressor is being turned off. I haven't had a chance to duplicate the hot A/C idle problem, but I did have it running with the hood up the other night (not as hot) and I heard the A/C clutch kick off, I looked down and sure enough it wasn't spinning the compressor. It came back on shortly, but if it did that at night with lower ambient air temperatures, perhaps its doing it during the extra hot times. Next time I get hot air at idle, I'm checking to see if the compressor is engaged.
BTW, even at idle there is A LOT of heat pushing through the engine compartement. I had a hard time telling, but I think I could observe the fan clutch (possibly electric) engage and dis-engage. The Fan appeared to spin at a different speeds then then drive belt, and I could feel and extra rush of hot air. I wish I had some way of measuring the air flow and see how much the fan speed varies.
