Biodiesel Conversion
Old 07-12-2007, 12:44 PM
lawlor's Avatar
lawlor
lawlor is offline
Does any body know what I would need or could lead me in a direction to start? I want to look at converting my 02 X. Thanks.
Old 07-12-2007, 12:49 PM
Btravelen's Avatar
Btravelen
Btravelen is offline
Properly produced Biodiesel should require no modifications. WVO and SVO DO. You would have better luck posting in the 'Bio' forum.
Take Care
Old 07-12-2007, 07:32 PM
fomoco_1's Avatar
fomoco_1
fomoco_1 is offline
Speaking from experience....I gave it a shot for 10,000 miles in my Kenworth. Fuel mileage decreased 6 %. Short of making someone FEEL better about the environment,its not what it was cracked up to be. Anyway,noone would use it if it wasn't so heavily subsidized by the government.
Old 07-12-2007, 08:44 PM
lawlor's Avatar
lawlor
lawlor is offline
Old 07-12-2007, 09:04 PM
willbd's Avatar
willbd
willbd is offline
Nothing for Biodiesel. If you want to run WVO you need to install a heated fuel tank system.
Old 07-12-2007, 09:24 PM
lawlor's Avatar
lawlor
lawlor is offline
Which is better, B20 or B99? What are the differences?
Old 07-12-2007, 09:28 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
differences are B20 is 20% biodiesel and 80% petro diesel and B99 is 99% bio and maybe 1% petrol diesel. Better is questionable, depends type of answer. the B20 will of coarse give you the benefits of running bio in added lubrication and will clean your fuel system and should improve your fuel economy. B99 might hurt your economy slightly (I don't see it with mine but many say it does) but had the benefit that darn little of your money is going to the middle east.
Old 07-12-2007, 09:34 PM
lawlor's Avatar
lawlor
lawlor is offline
The only place around here has B99 but I have the Superchip and it is set on the 3rd stage so I'm pretty sure my fuel economy would go down but I think it would go down a whole lot. Do you also need ot get a new fuel filter? I see a bunch of people saying that. If it cleans the fuel system then why would you need a new filter, or will the filter just catch all the stuff from the system? Thanks.
Old 07-12-2007, 09:39 PM
monsterbaby
you will want to keep a new fuel filter with you because it will clean out the fuel system and the filter better catch it but that will plug it if your system is really dirty. but once you have gotten it cleaned up then the filter changes will go back to normal
As to the economy I get around 16-17mpg on #2 diesel get 17-18on approx B25 and around 16-17 running B100 so you can see it really isn't changing my economy much.
Old 07-12-2007, 09:41 PM
lawlor's Avatar
lawlor
lawlor is offline
So could I jump right into filling my tank with B99?
Old 07-12-2007, 10:50 PM
Flea's Avatar
Flea
Flea is offline
Yep. All Bio goes straight into and unmodified vehicle.
Bio is modified outside of the tank and Veggie or WVO is inside.
Old 07-12-2007, 11:00 PM
lawlor's Avatar
lawlor
lawlor is offline
Thanks for the info.
Old 07-13-2007, 08:25 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Moved to ...here....enjoy~
Old 07-13-2007, 07:59 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
I respectfully disagree, I've been making and using biodiesel for 4 years, and Have noticed a slight increase in fuel milage. Some people have said they see no differance at all. I run a 3,000 acre wheat ranch with biodiesel only and will NEVER go back to dino-diesel! All my diesels run smoother, quieter, with 0 problems in the last 4 years. My fuel costs less than $1 per gallon, and my $$$ stay on the ranch and don't go to some "rag-head" !
If you want to find out more about making and using biodiesel you should go here first: http://www.biodieselcommunity.org And look at past threads on this forum, there are lots of us here sharing info on making bio.
Old 07-16-2007, 10:21 AM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
I dont know what you expected so I cannot address that issue; however, the advantages to BioDiesel are not better fuel economy or cheaper fuel. The big advantages ares reducing our dependance on foreign oil, putting one of our national resources (our farmers), back to work, and simultaneously reducing greenhouse gasses.
Anything we can do to reduce the flow of cash to the terrorist supporting middle east regimes is beneficial. Anything we can do to reduce our dependence on foriegn sources of a vital resource is beneficial. Anything we can do to put folks to work is beneficial. In the short term it may cost more to operate a fleet of vehicles on BD but long term we (the nation) win and each individual benefits.
Myfreeford
54
02-15-2019 04:33 PM
Truckin23
10-06-2014 08:20 PM
dale i
09-22-2002 09:37 AM
rogwelch
02-12-2000 11:29 PM
Quick Reply: Biodiesel Conversion
