Hey, pardon my ignorance to this group of experts, i got your name from another thread and found you and could figure out how to start a new thread with you so i'm popping on a pre-existin conversation with a new question that is unrelated to this thread (sorry about that).
Here is my question. I have a 1966 F100 300 cu inch 6 cyl with a manual T18 transmission. I'm trying to fix the "slop" in the shifting pattern. When i started a new thread with this question your name came up. Apparently there is a pin i can replace that should take alot of the slop out of the shifting pattern. Do you have the Ford part # for this pin? Do you have any pics of it and the transmission so i can replace it myself?
Many thanks for any assistance....Chris
Bill, could you help with these ford yblock part numbers? Timing cover number EBV 6059 G and water pump ECW 8505 ? Can you tell what engine they came off of?
Thanks
gordelgordo
Thanks
gordelgordo
I'm not Bill, but you really should start a NEW thread.
EBV6059G is a timing cover for a 1955 239 Y block truck engine
ECW8505A is a casting number for an off brand waterpump. they are marketed on ebay by a Chevy guy as being for a flathead, which they are NOT for, but they are actually the same or at least they look to be copies of a B6A8501B which is a water pump for a 56-59 272,292 or 312 Ford
Hello my name is Chris I have a 2000 f250 7.3 that 2nd gear is out of my transmission has numbers RFF81P-7006-CA AND the one I want to put in has numbers RF3C3P-7006-AG will this trans work? Would appreciate any help thanks Chris
Geez Louise, 's are posting in this 1948/56 F1/F100 and larger F series forum...that own much newer trucks.
You want the 1999-2016 SUPER DUTY forum for F250/350/450/550 with V8/V10 gas and V8 diesel engines.
So they heard about the famous NumberDummy on FTE with answers to all their parts questions. They did a search for "NumberDummy" and this thread title popped up. Bingo, they found you...
Originally Posted by Harrier
Or it could be that Newbie's know how cool the 48-56 group is and just want to be part of our awesomeness.
You know everyone wants one of our trucks.
Maybe a little from column A and a little from column B?
