Jump start a Power Stroke
Old 06-30-2007, 03:34 PM
fuzzy1626's Avatar
fuzzy1626
fuzzy1626 is offline
Hello; I belong to the IDI forum but my Dad has a 99 F350 Power Stroke with bad batteries. We tried to start it today using my F250 but it just does'nt seem to turn fast enough to start. My question is,does a Power Stroke need to have A certain amount of power in the batteries to start because of all the electronics or does it have to turn over fast enough to get the oil pressure up to fire the injectors. We were going to take it to Advance to get new batteries but I guess I'll have to pull them and get new ones my self. Thanks in advance for any help .
Old 06-30-2007, 03:37 PM
Mr. Bob's Avatar
Mr. Bob
Mr. Bob is offline
I have had to jump both IDIs and Powerstrokes when I had my IDI....
With it running and 2 sets of jumper cables it was not enough... I found that it took either 2 vehicles, or my truck and a fully charged battery to get it going....
Good luck!
Bob
Old 06-30-2007, 03:38 PM
v10squirrel's Avatar
v10squirrel
v10squirrel is offline
yes a set rpm is needed for the pcm to start injection
Old 06-30-2007, 03:46 PM
fuzzy1626's Avatar
fuzzy1626
Thanks for the help.
Fuzzy 1626
Old 06-30-2007, 04:19 PM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
Try putting the jumper cables on for 10-20 mins while the donor vehicle keeps the RPM's up. That way you charge the dead batts a bit before trying to start it. The PSD needs a lot of juice to fire the injectors.
Old 06-30-2007, 06:21 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
Fat Diesel says it right. Let the dead batteries charge up a bit first.
Old 06-30-2007, 08:56 PM
clem1226's Avatar
clem1226
clem1226 is offline
Single set of cables on the drivers side battery adn let her charge for 15 or 20 minutes as has been previousley stated. I have had to jump mine several times after the wife left the key in the run position?all night....with the motor not running. I still cant figure out how she does that but ...but I usually just use the minivan and let her charge, even on 0 degree mornings she has fired up after 20 or so minutes.
Old 06-30-2007, 10:10 PM
jomac11's Avatar
jomac11
jomac11 is offline
When my buddy's alt went dead on his 01, we jumped it off his 70 chevy c-10 after about 5 minutes with no problems at all...
Old 06-30-2007, 11:07 PM
indebt's Avatar
indebt
indebt is offline
man I hate when I have to start mine, I usually put the wifes burban and my battery charger to get it going after about 20min
Old 07-05-2007, 07:40 PM
fuzzy1626's Avatar
fuzzy1626
Batteries were absolutley shot. They were the original factory batteries from 1999. Two new Advance Platinum's and it starts like a PSD should. Thanks to all for the help.
Old 07-05-2007, 10:54 PM
dnvoss's Avatar
dnvoss
dnvoss is offline
always check the batteries...new batteries will make it start right up
Old 07-06-2007, 06:25 AM
JOE-M's Avatar
JOE-M
JOE-M is offline
I think he got more than his money's worth out of those batteries.
joe
Old 07-15-2007, 11:55 AM
PSDLOVER's Avatar
PSDLOVER
PSDLOVER is offline
You can have mine
Seriously, I have two 65's sitting in the yard. I changed out mine with Optima Redtops because of vibration leakage thru the covers. I didn't want to tow West in the summer heat like that. My truck does alot of bouncing around. The Optima are awesome but do cost more. This was my 2nd battery changeout on an 02.
Rudolph 1
05-14-2017 06:19 PM
Alan Cadiz
05-03-2017 04:37 AM
mblayton
Ford Truck Parts for Sale
09-21-2016 01:32 PM
mikefred44
03-22-2016 05:34 PM
stampeder
1999 to 2016 Super Duty
06-21-2009 09:45 AM
Quick Reply: Jump start a Power Stroke
