Jealous Friends Neighbor Brother in Law
Just Harpooned my F250 now everyone I know with a Diesel wants to know if they can be Harpooned?
Friend with a 05 Dodge with a 50 mile 1 way commute is really interested.
Friend with a 06 F350 (I'll help him) he also has a long commute.
Neighbor with a 06 GMC, short commute but frequent LONG trips.
Brother in Law with a 05 Chevy, lots of towing.
Anybody know if these off brand trucks can be Harpooned?
THANKS
THANKS
THANKS
THANKS
THANKS
THANKS
I thought the issue was that by doing so the tank vented better when filling and reduced the "foaming" issue?????
Originally Posted by Beachbumcook
What does the amount of miles they drive have to do with harpooning the fuel tank?
You can get 34 gallons in these 28 gallon tanks, You can do it without the harpoon mod if you slowly keep filling once it clicks. I always do it, Ive gone 100 miles before my fuel gage even started moving.
I dont know exactly how many gallons dodge or chevys will hold. I think the short bed chevy tanks are only like 24 gallons, not sure how much more they would actually hold.
My understanding is that ford uses the same superduty tank in gas or diesel trucks. As the gas trucks need air for them to run properly the filler tube and air vent extends about 3-4 inches into the tank causing an air void on the top portion so that your pump stops when the fuel hits the vent at 28 gallons for a 34 gallon tank. Diesel trucks do not need that air void. Ford likely did this for mass production and cost savings. This is just another thing ford could of did better.
I am not as familiar with the durmax's but some of my cousins run the dodge cummins and when they fill up there is very little to no more fuel to put in. I get the impression Dodge put a diesel tank in a diesel truck rather than ford putting a gas tank that will also work for a diesel truck. Thus the dodge may not have anything to harpoon as their tank is actually or close to "full" when their pump clicks.
I hunt and fish 100's of km's in remote areas away from the nearest fuel station and want the security of having every litre of fuel with minmal time to fill it.
I always spend the time to fill it to the neck but it is just that a pain in the neck.
I will also be harpooning my truck when I get the time.
Originally Posted by Cowboy Brett
Does anyone know why they set up the vent like that to begin with? It's a pain in the butt, that's a fact. The harpoon mod is a real time saver of you've got to fuel up a lot, particularly if your regular station has the larger diameter truck nozzles.
Wish, I dont spend 15 minutes, more like 3-5 minutes. lol. The clerks always ask me if the pump is working right. But its nice getting the extra miles. I wanta do the harpoon one of these days, just sounds like to much work, I dont mind spending a little extra time at the pump. I plan on getting a secondary tank in the near future though.
A-rod.
Instead of dropping the tank out to harpoon it and avoid an onerous procedure you can do an alternative approach a friend of mine did which took him an hour or so.
If you have access to a hoist you can simply unbolt your box lift it up move your truck forward and access your tank from the top and do the harpoon. This avoids messing with the tanks fuel lines and moving a partialy filled tank.
Something to consider if you or a buddy has the hoist type set up.
I am going this route when I got the time and access to my budy's shop.
