1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Problem w/ EGT gauge
Old 07-02-2007, 08:10 AM
Ernroe's Avatar
Ernroe
Ernroe is offline
I bought a used Auto Meter EGT gauge (4743) that came w/ a new sending unit/pyrometer probe. I had a local performance shop install it and a boost gauge. This is the problem; When the ignition is off it reads 250 degrees and when truck is running it reads 0 to 100 degrees. The exhaust was drilled and tapped and probe was installed and the wire colors match up. The EGT gauge was working when removed from the other truck. The boost gauge works fine.
I would like to hear your thoughts on this problem.
Ernie
Old 07-02-2007, 08:21 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Sounds like an installation problem.
Old 07-02-2007, 08:25 AM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
EaTmYtAiLpIpEs is offline
sounds like the shop messed something up.
