1973 460
It is an ok engine is stock form. The heads can be ported and have larger valves installed to be almost as good as a set of D0VE heads with the same work performed. The one mod that will give the most performance cost effective wise is a straight up timing set, followed by a set of headers. I am running a 460 with D3VE heads on it and can't complain. The larger combustion chamber allows for more configurations verse the 76cc heads IMHO.
I dont know if there is a big difference between the 73 and 74 460 but my 74 460 is plenty strong. It has a straight up timing chain and a 305 duration .580 lift cam with a rocker conversion kit to have adjustable rockers. The truck it is in ran mid 8s in the 1/8th mile. That is respectable for 5000 lbs of street truck.
Originally Posted by ford79man91
ok thats good to know the truck that im getting it out of someone stole the 4 barrel carb and the distributor so ill have to use the distributor outta my 351m but a good four barrel isnt hard to find...thanks for all the info guys
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributor.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
FTE Sponsor
Ford4X4ingboy
09-04-2011 11:11 AM
Big_MARK
09-01-2008 09:56 PM
duane006
04-24-2008 09:33 PM
1973, 1979, 370, 460, 73, built, distributer, distributor, electronic, engine, ford, ignition, parts, points, specs
