Option Question
Originally Posted by jam105
The trailer I pull is 13K loaded when it comes time to change can I go with a lighter tire?
Kind of funny when they unloaded this truck from the transport I was there and took it on the spot...Had a "A" plan so still was under what a 250 list for.....
The 225/70R19.5 tires have these load ratings
F = 3640lbs
G = 3970lbs
Without weighing your truck & trailer loaded ready for travel at a CAT scale you will not know the actual load on your rear axle and tires. Weigh your rig and then you will know what load range tire you need to run.
One other thing, most tire websites list air pressure table for commercial tires, so when you are empty you can air the tire down for the lighter load.
Here is the link to the inflation tables on the Continental Commercial tire website.
http://www.conti-online.com/generato...les_pdf_en.pdf
[QUOTE=blackhat620]The lightest load range you will find for 19.5" wheels is Load range "F" (12-ply) your truck came from the factory with Load range "G" (14-ply).
F = 3640lbs
G = 3970lbs
www.conti-online.com/generator/www/us/en/continental/transport/themes/tech_info/downl/load_infl_tables_pdf_en.pdf[/QUOTE]
Wonder if this would help with the wondering on grooved pavement?
F = 3640lbs
G = 3970lbs
ewatness
148
11-06-2020 04:55 PM
rjlabonte
1999 to 2016 Super Duty
04-20-2012 04:32 PM
