Flashing Air Bag Light - Lamp Fault Code 27
Old 02-22-2013, 11:04 AM
Slingnsteel's Avatar
Slingnsteel
Slingnsteel is offline
Great post, easy fix. It cost me $2.14 with tax to fix. Mke sure you get a 12v LED. Tools needed, solder iron, solder, solder sucker. I could not find my solder sucker so used a air hose and blew the solder out from underneath the weld.
SM
Old 05-04-2013, 01:23 PM
Henry Statham's Avatar
Henry Statham
Henry Statham is offline
The Fix worked! Thank You!
1999 Ranger - didn't have to pull the radio but it took a bit of doing to get the switch cover off. Radio Shack's LED selection was pretty thin for 12V, finally found a red one. I also figured out a way to make sure I have the LED in correctly. Plug the module back in, and put the LED wires on top of/ in contact with the old ones. Light on for lamp test when you turn on the ignition = correct, otherwise ignition off, reverse, try again.
Enjoying that cold frosty beer now as directed by the procedure...
Old 05-12-2014, 09:45 AM
beachcamperf250's Avatar
beachcamperf250
beachcamperf250 is offline
I wanted to add my 2 cents to this great thread that saved me a huge amount of money. On all lights like this the Longer pin is always Positive.
Picture of Red LED from Radio Shack:
Picture of LED installed, notice longer pin on right (+) (cut before final install):
Old 06-08-2014, 09:07 PM
rbbarron's Avatar
rbbarron
rbbarron is offline
Great thread, worked great. This sight has been good to me & my new/used truck!
Old 06-24-2014, 08:27 PM
Reichenbach79's Avatar
Reichenbach79
Reichenbach79 is offline
Awesome thread.
This is a great thread. I picked up a green led since the interior ligjting is green and a resistor,(Radio shack didn't have a 12 volt green led). Found out I am not the best at soldering on a circuit board, but with a little patience i got it done. Thanks again!
Hessmonster
1999 to 2016 Super Duty
11-13-2015 03:09 PM
gcburkett
1997-2006 Expedition & Navigator
08-08-2015 01:41 PM
7700Rob
1997 - 2003 F150
16
02-16-2015 03:07 PM
makuloco2000
1997 - 2003 F150
02-15-2014 09:58 AM
AAS
1978 - 1996 Big Bronco
11-09-2003 05:45 AM
Quick Reply: Flashing Air Bag Light - Lamp Fault Code 27
