2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Air ride and Easy Entry
Old 05-23-2007, 08:01 AM
stimpy4242's Avatar
stimpy4242
stimpy4242 is offline
I am curious, the ford website says air ride suspension will lower your car 1 inch in park and raise it 1 inch in 4wd. Can you actually see this happen if the door is open and you are looking, or feel it happen? Because I see and feel nothing..i have even measured and nothing...
Easy entry, this means the seat should slide back when you put it in park right? Because I moved my seat most of the way forward and put it in park and nothing...
YES both of the options are selected in the menu.
Old 05-23-2007, 12:58 PM
ExpyBob's Avatar
ExpyBob
ExpyBob is offline
I doesn't work until you pull the key out or when you put it back in.
Bob
Old 05-23-2007, 05:47 PM
stimpy4242's Avatar
stimpy4242
Bob
no offense bob, but are you saying I need to pull my key out in order to put it into 4wd to have it lift up??? Which of the two are you responding to?
Old 05-24-2007, 04:54 AM
ExpyBob's Avatar
ExpyBob
ExpyBob is offline
The seat. It works with the key for Easy Entry if you enabled it.
revytrucks
1997 - 2003 F150
154
12-18-2021 01:51 PM
ptmares
03-26-2013 08:39 PM
cfranc
05-24-2010 01:00 PM
polarbear
Ford vs The Competition
16
02-27-2006 09:53 PM
polarbear
13
01-30-2005 03:30 PM
Quick Reply: Air ride and Easy Entry
