Before I do my tranny service....
Old 05-09-2007, 05:13 PM
the_sharkster's Avatar
the_sharkster
the_sharkster is offline
Does anyone have a way that I can drain the torque converter when I do my trans service, or is that something that has to be done with one of those vacuum machines?
I'd like to do it myself, if there is a way.
Any help is appreciated. Thanks Guys.
Old 05-09-2007, 05:18 PM
jroehl's Avatar
jroehl
jroehl is offline
Yes, you can drain it yourself. You have to remove the inspection plate at the bottom of the bellhousing (have to remove one starter bolt or the whole thing), then you'll have to turn the engine by the crankshaft pulley until the drain plug on the T/C comes around. Unbolt it, and you'll have a nice puddly of tranny fluid.
Jason
Old 05-09-2007, 05:21 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
which trans?
if e4od you remove rubber plug tap ignition key with coil wire off distributer until drain lines up.
have a big pan handy, a lot of fluid in there.
no inspection plate on an e4od.
Old 05-09-2007, 05:24 PM
the_sharkster
Its an AOD trans.
Thanks for that info. I hate to do a job more than once.
I want to thank everyone here in this forum for all the great info. Ive been working on cars a long time, but this old dog learns new tricks all the time.... LOL
