Ontario Chapter Join Chapter>, Leader: loudfords
*** IMPORTANT Message For Ontario Chapter Members! ***
Old 04-28-2007, 04:29 PM
Beast12's Avatar
Beast12
Beast12 is offline
Post *** IMPORTANT Message For Ontario Chapter Members! ***
The Webmaster has run an automated routine in the last week for Chapter Memberships. Some of you had your membership removed. Not to worry, there is a reason behind it.
First, check out the following link and see if you are listed or not. If you are, then you don't need to do anything.
https://www.ford-trucks.com/forums/3...r-members.html
If you are not listed (but used to be) here is the reason: the program that was run checked for your location that is listed in your profile. Since this is the Ontario Chapter it was looking for Ontario. If you did not fill that in then it deleted you from the membership list.
All you need to do is click USER CP at the top left then click Edit Profile. In the fourth box down (on the right) put ON. Then scroll down to the Additional Information section. You might as well put your location in there as well. That's the location that shows up in your posts. Then Save Changes.
Now, that is done click Chapter Memberships on the left hand side. Then on the right scroll wayyyyy down to the bottom to the Ontario Chapter. Click JOIN CHAPTER. Send in your request and I will add you to the list again.
If ANYONE has any questions about what to do then DO NOT hesitate to ask.
-Matt
Old 04-29-2007, 10:50 AM
Beast12's Avatar
Beast12
Beast12 is offline
Just an important step to let people know. After you add ON to your profile you MUST do the following:
Just adding ON does not add you to the list.
-Matt
Beast12's Avatar
Beast12
Beast12 is offline
pinerider added to Chapter Membership.
Old 04-29-2007, 09:10 PM
Beast12's Avatar
Beast12
Beast12 is offline
Blackstock added to Chapter Membership.
Old 04-30-2007, 11:50 AM
loudfords's Avatar
loudfords
loudfords is offline
Side note: you can only be a member of one chapter any more, not multiple chapters like before.
Old 04-30-2007, 07:24 PM
Beast12's Avatar
Beast12
Beast12 is offline
That is correct Chad. Thanks for bringing that up. It is a way to help organize the chapters more. Some people were members of up to 10 chapters. Kinda pointless...
-Matt
Old 05-02-2007, 06:51 PM
Beast12's Avatar
Beast12
Beast12 is offline
Hillcrest#9 added to Chapter Membership.
waboose added to Chapter Membership.
Old 05-10-2007, 08:44 PM
Neilster999's Avatar
Neilster999
Neilster999 is offline
Thanks I finally found out how to joint i could not figure it out..........Neil from Barrie
