seting ignition timeing on f-150
hello i have a 92 ford f-150 4.9 l6 300cu
im haveing trobble seting the timeing
i haven't done this in a long time
how times would it take to get where it is i took the plug out turned over
with my finger in the hole untill the presser blow my finger off
i don't know if they do it that way still
i don't know the dealers set it at factory mine is 10 deges
i even triyed to take the disstrebutor out and turned the rotter to no 1 cyl
but still nothing something im doing wrong
but i noticed there marks on the disstrebutor base and block
The computer on your 1992 4.9L L6 controls the advancement of the ignition timing as the RPM's and vacuum change in your motor.
So, to begin timing your truck, you'll want to hook up a timing light to the motor (if it's already running) and setting it at 10* BTDC with any spark advance lines or wires running to the computer disconnected. This is to keep the timing from advancing while you lock in the base, or initial timing.
To do it if the truck isn't running, find TDC on the #1 cylinder. Then, turn the distributor (while it's out of the motor) to where the rotor is pointing at the #1 spark plug tower on the cap. Once it's lined up close as you can get it, slip the distributor in and see if you can get it started. If you can, set your base timing and you're good to go.
dtcohen
12-20-2018 03:41 PM
briguy
17
01-23-2007 06:05 AM
