Lift a Econoline?
#46
Your van is a 86, mine a 93, so may be it's a bit different for a body lift but I'm still curious to know.
What have you done for the bumpers? Modified the brackets to lift the bumper?
If yes, does that make the frame visible?
Do you have pictures of the bumper and bracket area?
Thanks.
Thanks.
The lift kit for my Excursion was all 3" blocks, but expensive because of the welded bumper relocation brackets. I bought enought 3" blocks for my van for under 100 dollars without any hardware, and bought 10-11" bolts and large/thick fender washers
to spread the stress on the inside sheet metal from a local nut/bolt store. Also went up one size for strength and just bought the corresponding tap for under 10 dollars to re-tap the retaining washer/nut combo on the underside. They are one-piece on my '86 E-150 under the body bushings. Easy to see from the underside. I have pics for anyone that would like me to e-mail them. Still haven't figured out how to post here with a URL.
#47
#48
#50
You'll run into issues trying to do a suspension lift, the rear is easy, but twin i-beam front require a lot to insure you retain the correct camber. There are companies with a lift kit, thus replacing the factory parts, but they are quite expensive due to the fact you will be practically replacing the entire front end. I have wondered if the earlier truck TTB drop brackets that come in lift kits would work on a van, after all, it's almost the same setup, you'll just have to locate some taller coil springs. Since our vans 93+ have camber inserts, allowing for adjustment, I wonder if it would be possible to lift or lower one 2", I want to bring mine down, but as I said, you have to locate a place for coils.
#55
#57
I just bought a 1985 F-250 with 42,000 miles, all stock. I would like to either lift, or lower the van 2", I haven't decided which, yet. I'm only interested in suspension mods, no body lifts.
Are there lift kits for the older vans? I've only seen kits for the newer style.
What about lowering the van? Is this easier?
Also, I did a search and couldn't find a chart for the type of wheels that will fit on a stock 1985 E250. Does anyone know how big (and wide) I can go without rubbing?
Thanks in advance for the advice, it's appreciated.
Steve
Steve
#58
Lifting and lowering is a big issue due to the I-beams, there is a drop kit with tubular beams, you do not want this due to them not being structurally able to carry the load without bending, that's why Ford made them in the form of an I-beam, similar to bridges. They have to be formed just right, at the right angle for the location the coil spring will have them at or the wheel will be out of camber, tilting in or out, causes tire wear and issues with steering, unsafe handling is a result.
I put up a topic about putting a TTB in my 99 or lowering it, and there was a response with a site that has drop beams, the kind I'm wanting to buy, check it out, they may fit the older models.
#59
Is it 2wd or 4wd.that will make a difference. If its 4wd anything from th80's in 8 lug will fit it.same as the 2wd.AS far as rubbing you would have to try it or ask your local tire dealer.They should know.
Steve
Steve
