V-10 Plug Change Interval Reg Service vs Heavey Duty
I have a 99 Ford V-10 that I pull a 5th wheel with. I believe the owners manual directs changing plugs at either 50,000 or 60,000 miles under heavy duty service use, instead of 100,000 miles.
I talked to my mechanic about this and he could not think of any reason why they would suggest more frequent change under heavy service unless one was overheating the engine. I had him pull one plug to check it aroung 70,000 and he said it looked fine.
Does anyone have any knowledge about the pros and cons of this recommendation. I presently have 82,000 on the truck and it runs fine and gets decent mileage.
Thanks, LIKENIT
Thanks, LIKENIT
Every plug wears each time it fires.
So, the higher revving the motor, over so many miles, the more the plugs wear.
I'd also suspect that the denser the air/fuel mix, the more they wear also. More O2 to oxidize the electrodes.
So, work the engine, the plugs wear out faster. Plain and simple
LIKENIT
1999 to 2016 Super Duty
07-26-2011 07:11 PM
