Burning Used Motor Oil
Old 04-17-2007, 06:26 AM
oldpaintguy's Avatar
oldpaintguy
oldpaintguy is offline
Has anyone tried used motor oil as a fule in the 7.3 engine?
Old 04-17-2007, 07:20 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Not a good idea, but read this anyway: https://www.ford-trucks.com/forums/4...motor-oil.html
Old 04-17-2007, 07:56 AM
mechmagcn's Avatar
mechmagcn
mechmagcn is offline
While I don't run used oil in my 7.3, I do run a 25% mixture in my 6-71 Detroit.(the old 6-71 really doesn't like this new fuel) When I have clean hydraulic fluid, I will run as much as 50% mixture of it. I have run this engine for several years at these rates with no adverse affects.
I have a friend who is running an older Mecedes 4cylinder non turbo on 75% used oil and 25% gasoline. He has run this car for over 2 years like this, and has no problems with it. He does have a mixing system which filters down to 2 microns.
Old 04-17-2007, 08:06 AM
firemediceric's Avatar
firemediceric
firemediceric is offline
Coincidence that I just posted a similiar question here:
http://biodiesel.infopop.cc/eve/forums/a/tpc/f/9751014871/m/5101055591
In reading the above link from Fabmandelux, it seems that some have run UMO with next to no filtering. In my query on the other forum I am talking about processing it just as I do my WVO, which many call overkill in the steps I take. This would include a mistwash for acids, settling, heating to seperate water and filtering down to 1 micron nominal.
Old 04-17-2007, 09:37 AM
Talyn's Avatar
Talyn
Talyn is offline
I have a friend they run 50/50 on the farm.
I think they only run 25/75 in the trucks if they do though.
If you are going to mix in motoroil, Filter it good. There are metal particles in the oil, injectors probablywont like them much.
I would Mix it slow. start out with a small mixture if your serious with it. only 10/90.
To much and they get a little cranky. Anotehr guy on here tried it though, he said that his ford took a dump. =*( poor truck.
Old 04-17-2007, 01:01 PM
tx4wd's Avatar
tx4wd
tx4wd is offline
Do you recall some keywords in the thread so I can find it? This is something I've been seriously considering as I'll be picking up an older diesel soon....maybe today
Thnx.
Old 04-17-2007, 01:39 PM
Talyn's Avatar
Talyn
Talyn is offline
its in one of the current active threads here.
Old 04-17-2007, 01:41 PM
Talyn's Avatar
Talyn
Talyn is offline
Old 04-17-2007, 01:57 PM
tx4wd's Avatar
tx4wd
tx4wd is offline
Red face
Last edited by tx4wd; 04-17-2007 at 02:08 PM. Reason: disregard---didn't click to page 3...duh
Old 04-17-2007, 02:19 PM
Talyn's Avatar
Talyn
Talyn is offline
what kinda look is that?! haha
Old 04-17-2007, 02:24 PM
tx4wd's Avatar
tx4wd
tx4wd is offline
That's the look that I posted that I didn't see where his motor blew up but where it only clogged the filter then after posting my response here I realized I hadn't clicked to page 3....since I can't delete posts here just dropped it to an embarassed look.
catbird7
Bio-diesel, Propane & Alternative Diesel Engine Fuels
79
01-12-2008 10:31 PM
Beachbumcook
07-05-2007 07:42 AM
ranger rules
General Automotive Discussion
20
06-04-2007 05:23 AM
ddurant
05-30-2003 11:58 AM
jamie m
03-03-2003 12:34 AM
Quick Reply: Burning Used Motor Oil
