You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Is anyone using a "Simple Centrifuge" for processing their WVO?
I'm thinking of buying one. www.simplecentrifuge.com.
It processes about 5gal/hr of heated oil. Water separates out also.
About $700 for centrifuge and motor.
Mike
A while back fabman was working on an old washer to use as one. I don't know if it worked out or not. Maby he will jump in here.
__________________
'79 F250 4X4 Super Cab, Dana 60 front and rear, Cummins Turbo Diesel, NV4500 transmission, NP 205
'06 F250 4X4 V10 Super Cab
'57 F250 rust pile
Bitter American clinging to his guns and religion.
Thanks jim. I'm looking for something compact and lightweight, as I'll be processing out of my cabover camper while on a yearlong tour of the US, Mexico and Canada.
Although pricey, this "simple centrifuge" unit will weigh about 50 lbs and fit into a 18x18x24" space. I was hoping to find someone actually using one for feedback prior to purchasing one.
Thanks Erick. I've seen the thread about the diesel craft fluid driven centrifuge. It needs something like a power steering pump and an electric moter to work and takes up more space. Its cheeper, though, only about $250 for the centrifuge part. You have to heat the oil in any case. A 5 gal propane turkey roaster works fine for small batches.
Mike
I think when I talked to Fabman about that it was really hard to get up to velocity to seperate the glycering and bio. I went with a hydrocyclone that is small and with enouph pump pressure you can get it up to 9k rpm. The glyc and junk come out the bottom and bio out the top. I think I have a pic in my folder.
__________________
585,000+ miles on original engine. Goldie 00 F-350
