pics of lowered 67-72 ford trucks?
Old 08-22-2010, 05:16 PM
Quick69's Avatar
Quick69
Quick69 is offline
new wheels are on along with some 255/70 bfg's
  #167
Old 08-22-2010, 05:20 PM
Phil105's Avatar
Phil105
Phil105 is offline
VERY NICE LOOKING TRUCK - hope you're staying close to original.
Phil
  #168
Old 10-08-2010, 03:39 PM
tcscustoms's Avatar
tcscustoms
tcscustoms is offline
Tony, Love the truck. I have been searching for some ideas for a 68 that Im about to buy and you just totally put me in the zone. Cant wait to get mine to the hight of yours. I will be runnin without bags for a while to. But, I still want the stance that your truck has, even if I never get bags at all. Is the ride still smooth at that level?
The following users liked this post:
  #169
Old 10-08-2010, 05:17 PM
choochoof150's Avatar
choochoof150
choochoof150 is offline
My rims are 20x9 front and back. Tires are General exclaim uhp's 235/30 front and 265/50 out back.
  #170
Old 10-08-2010, 11:31 PM
carpenter547's Avatar
carpenter547
carpenter547 is offline
Originally Posted by MychalCrowson
"Photo Sharing and Video Hosting at Photobucket">
oh man brb gotta change my shorts.
  #171
Old 10-09-2010, 12:20 PM
lucky_strike's Avatar
lucky_strike
lucky_strike is offline
is it hard lowering the trucks with the twin I beam, id really like to lower mine but so far the shops that ive called said they done do it.
  #172
Old 10-09-2010, 12:22 PM
carpenter547
depends
lowering difficulty depends on your desired drop and your budget.
  #173
Old 10-14-2010, 09:16 PM
westco's Avatar
westco
westco is offline
Originally Posted by Quick69
just lowered mine last weekend
1/2 flip on rear
1 1/2 coil cut on front
looks good...what does 1/2 flip on rear mean?
  #174
Old 11-03-2010, 02:42 PM
Quick69's Avatar
Quick69
Quick69 is offline
it means you flip the front hangers of the leaf springs upside down
  #175
Old 11-03-2010, 02:45 PM
Quick69's Avatar
Quick69
Quick69 is offline
  #176
Old 11-03-2010, 07:43 PM
cavinandpavin's Avatar
cavinandpavin
cavinandpavin is offline
Originally Posted by tgowers
if you want to go as low as mine you can't do it with beams.... my buddy and i used a 1971 lincoln front frame section from the firewall forward. the rear is c-notched. the lincoln front suspension is all stock... the control arms are stock, the shocks are stock, the disc brakes are stock, the sway bar is stock... the only thing that is not stock are the front springs... my buddy had an extra set of g-body buick springs that were the exact same size as the stock lincoln springs, so we put them in...they were free. good luck. look at my gallery and you can see a bunch of pictures.
tgowers, your truck sits perfectly. i have been on the fence on how to lower my 65. so i joined this site just to ask you a few questions if you dont mind. first, what model lincolin did you use? it looked as though it was the same width right? was the bolt pattern the same for the wheels or di you drill out the disks? thanks and again good job on the truck!
  #177
Old 11-24-2010, 07:59 AM
tgowers's Avatar
tgowers
tgowers is offline
71 lincoln continental. it worked out to be the perfect width. the bolt pattern is different, so i just ran the stock lincoln wheels up front. There was a ton of fab work, but you can look through my pictures and see a lot. the steering box from the lincoln won't work, i used a rack from a taurus. had to notch the front crossmember to allow the oil pan to clear. had to use a summit oil filter relocater to mount the oil filter to the core support. used the stock licoln disc brakes up front with the stock truck drums out back. wildwood proportioning valve to dial doan the rear brakes to allow full pressure to the discs.... and a residual valve in the rear line to keep the drums from draining off. fab new motor mounts. have a look at the picks, and then let me know any other questions.
-Tony
  #178
Old 11-26-2010, 07:17 PM
crewcabfan's Avatar
crewcabfan
crewcabfan is offline
here is some of my own.
this one i owned for a year, never really had a chance to drive it. too many mechanical issues.
this one my pride and joy.Name:  CIMG0001.jpg
  #179
Old 11-26-2010, 11:07 PM
lucky_strike
that crew cab is AMAZING!!
  #180
Old 02-11-2011, 01:12 PM
1971 f100's Avatar
1971 f100
1971 f100 is offline
1971 F100 Lowered with beams in front rear hangers and shackles. 390 C-6 all original paint. More plans for theengine and suspension. I think I'll leave the paint because of the pantina'd look.
Quick Reply: pics of lowered 67-72 ford trucks?
