Reversing Lights
Old 04-02-2007, 11:55 AM
ECA's Avatar
ECA
ECA is offline
Reversing Lights
I launch my Bass boat before sun up or after sun down alot. I would like to throw some major light when I put it in R, and have the option just to turn it on.
I have seen the White Night system sold by Sears and others. Does anyone know a " higher end " one?
Thanks,
Old 04-02-2007, 12:30 PM
sysman_rick's Avatar
sysman_rick
sysman_rick is offline
Wink
There is a led light bar called "Fire & Ice" from Recon. I have the White Night & the led bar. No problems illuminating the area behind my truck
Old 04-02-2007, 12:34 PM
ECA's Avatar
ECA
ECA is offline
Thanks Rick.
I am sure that the white night would be fine. Just looks a little plasticky. Was wondering if there was something that is built better.
Old 04-02-2007, 12:38 PM
F250_'s Avatar
F250_
F250_ is offline
Check this out. It's up to your task quite nicely!!
https://www.ford-trucks.com/forums/5...with-pics.html
Old 04-02-2007, 12:54 PM
ECA's Avatar
ECA
ECA is offline
Pete,
Thanks buddy! That is exactly what I did not know I was looking for
Old 04-02-2007, 02:03 PM
F250_'s Avatar
F250_
F250_ is offline
No prob. I felt the same way when i saw it just minutes before seeing your post. Always glad to help with what little I can.
Old 04-02-2007, 03:05 PM
CobraXP's Avatar
CobraXP
CobraXP is offline
Bear Hunter did an excellent job with his write-up! Thanks F250 for linking to that. I have been looking for a set of lights to put on my trailer, but I did not want to make it look like I had lights there. Those will work just fine...
Old 04-15-2007, 04:29 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
Received 2,779 Likes on 1,347 Posts
I bought a set of thoes oval fog lights at Wal*Mart last year with the intention of mounting them on the rear for light. I just haven't gotten around to putting them on yet...
Old 04-20-2007, 09:40 AM
sandmaniac's Avatar
sandmaniac
sandmaniac is offline
Just installed these on mine and they are great, inexpensive and BRIGHT.
Old 05-12-2007, 08:37 PM
Meatco1's Avatar
Meatco1
Meatco1 is offline
Here is another idea. http://www.defianttruckproducts.com/...rt.php?prt=120
When installed, they sit no lower than your trailer hitch.
Richard
Old 05-17-2007, 04:18 PM
JustDucky's Avatar
JustDucky
JustDucky is offline
The only issue with using it to back a boat down a ramp in the dark is the glare you will get off the boat hull. I put mine on the outside of the back bumper - there are holes there already so that I can light up the area outside the hull for better visability.
Old 05-17-2007, 07:30 PM
cdrmotorsports's Avatar
cdrmotorsports
cdrmotorsports is offline
You hit the nail right on the head. That's what I found with my old F150. All I could see was the hull of the boat glaring back at me. Meatco1: those brackets are awsome. I'm going to have to pickup a set or build me a set of those!
Old 05-17-2007, 08:50 PM
Meatco1's Avatar
Meatco1
Meatco1 is offline
cdrmotorsports:
When you can buy two of these brackes for less than $80.00, I'd rather just write the check. With the time saved from having to measure, cut, & weld, it's money well spent!
JMHO,
Richard
Old 05-18-2007, 06:52 PM
cdrmotorsports
That's exactly what I was thinking Meatco. I just like the idea of not having to drill anything on the truck and they look good! I'd rather have a nice clean fit than something I try to hack together lol.
Old 05-18-2007, 08:09 PM
bla1879's Avatar
bla1879
bla1879 is offline
the lights will glare off the boat hull, but when you have a truck as big as bear hunters your not going to be able to see the boat anyway, so its all good!
Quick Reply: Reversing Lights
