where exactly is the condensate drain for the a/c located ? i think mine is clogged
2004 f-150 heritage model 6 cyl . where exactly is the condensate drain for the a/c located ? i think mine is clogged because my cab floor is soaked under the carpet on the passenger side. it does not seem to be anti-freeze either.
The condensate drain is always loaved at the lowest point of the plenum. It is usally a plastic nipple that extends through a hole in the firewall, sometimes with a plastic or rubber hose. It is often hidden by other components such as exhaust and driveline stuff.
Identify the AC lines going through the dash. Draw a straight line downward to the bottom of the cab. The drain is usuallu on or near this imaginary line.
Most shops have a "special" air gun nozzle made up for clearing the drain. It usually a 6-10" pice of metal tubing with a 90 degree bend on the outlet. They just stick into the nipple and give it a shot of compressed air (and step back).
Steve
Steve
12amracer
1997-2006 Expedition & Navigator
06-19-2014 01:48 PM
overlandexpress
1999 to 2016 Super Duty
07-26-2013 10:02 AM
Tim Ervin
08-26-2005 02:36 AM
