7.3 oil pressure sending unit?
Probably the sending switch going south, but may be something else. The sending unit for our oil pressure is just a switch. It shows normal pressure at anything above 7 psi, and nothing at pressures under 7 psi. Also, it's not tied to the PCM at all. It's just a direct feed to the dash gauge.
Another thing to keep in mind, it takes the pressure reading from the HPOP resivoir. The bottom end of the engine has about 20 psi more than the HPOP res. Also, if your HPOP res was really at zero pressure, the injectors would not fire. So basically, your engine will quit running before any damage is done to the hard parts of the engine.
The pressure switch is located on the top of the HPOP res cover. If you remove the plastic "Powerstroke" cover to access the HPOP res, you'll see the pressure switch in the cover. It's on the passenger side of the two holes in the res. The driver's side has a plug in it with an allen head.
Originally Posted by CastleRocker
Where exactly would I find the HPOP res cover?
Ford and others have been doing this for years. Any vehicle that has an oil needle that doesn't move while driving is a fake gauge. I had a guy refuse to buy a Tundra I was selling because on the test drive he noticed the needle moving up & down with RPM, it has a real gauge. To him that indicated an oil problem....and this idiot was the "mechanic" inspecting the truck for the buyer. Manufacturers have figured out that a fake gauge is often better than a real one, and it's cheaper.
You are correct!
That so called 'mechanic' is an ignorant fool who knows nothing about cars, trucks or engines.
It's basically an idiot light with a needle to make the "savy" shopper feel good thinking he has a real gage and not just an idiot light, while keeping him from going to the dealer to bitch that his truck has less pressure than his neighbor's truck and demanding a warrantee repair.
xliarsenickx
06-23-2016 04:38 PM
CougarMark67XR7
05-04-2006 08:55 PM
