Ontario Chapter Join Chapter>, Leader: loudfords
67-72 lowered rear springs source
Old 04-27-2007, 09:05 AM
68murc's Avatar
68murc
68murc is offline
Question 67-72 lowered rear springs source
Hey guys,
Anybody here know of a Canadian (preferably Ontario) source for lowered rear springs for a '68 2wd. Thanks in advance.
Old 04-27-2007, 11:16 AM
loudfords's Avatar
loudfords
loudfords is offline
You can get the stockers de-arched at any reputable suspension shop if you're on a budget. How low are you going?
Old 04-27-2007, 02:53 PM
68murc's Avatar
68murc
68murc is offline
Well, it's kind of backwards, but I flipped my axle on top of my diff, and ended up with about 6-7'' of drop which is too low. I've got 3-4" between the diff and the frame. I need to have more arch put into the springs to take 2-3" out of the drop. That way, I'll end up with a 3-4" drop, which is what I want. I know it sounds wierd. The spring shop I called said they couldn't re-arch my springs because they're so old and would snap. I figured replacing the 40 yr old springs probably wasn't a bad iea anyway. The spring shop is gioing build me a spring set that should get the truck where I want it. I haven't dropped the truck off yet, so if something comes up quick, I could try something else.
Carmanico
09-07-2013 10:04 PM
archtaan
Ontario Chapter
651
04-30-2013 11:52 PM
49'er
04-11-2012 07:44 AM
88Vmax
Ontario Chapter
09-28-2009 09:12 PM
red ranger
11-10-2002 09:19 PM
Quick Reply: 67-72 lowered rear springs source
