Centering the steering wheel
I replaced the inner tie rods this weekend and now notice that the steering wheel is rotated about 5 degrees left when the wheels are straight ahead. I'm thinking that I need to turn the adjusting sleeve on the inner tie rod to shorten it in order to center the wheel. Am I correct on this?
Also, since I only did the inner tie rods, is there a reason to get an alignment. Maybe I'm missing something, but I don't see how the inner tie rod impacts alignment as it doesn't connect the two steering knuckles.
Any time you replace steering components an alignment is a good idea. A new component in the system changes the way the system is set up. Now, what do you mean by inners? Chevy uses inner tie rods with a pitman/idler arm setup. Ford uses a drag link instead, a totally different design. What kind of truck do you have?
Ducati07
07-04-2014 06:24 PM
triskadek
08-03-2010 01:11 PM
