Refilling the trans fluid through the side mounted refill hole
Old 03-09-2007, 06:10 PM
Ray Barnes's Avatar
Ray Barnes
Ray Barnes is offline
I have a 1992 F150 with manual trans. I would like to change the trans fluid. What is the best method of getting the new fluid into the side mounted refill hole? Is there a special tool or trick?
Any help would be greatly appreciated.
Thanks
Ray Barnes
Old 03-09-2007, 07:02 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
I bought a cheap $5 pump that screws into a quart bottle to fill mine. It does take a little time and your hand gets tired, but it's one of the easiest and cleanest methods I've seen.
Old 03-09-2007, 07:05 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
cheap pump is the way to do it,
you are draining old stuff and putting the correct stuff back in right?
Old 03-09-2007, 07:37 PM
Skandocious's Avatar
Skandocious
Skandocious is offline
I don't know about the M5OD but my brother was able to refill his ZF by pulling up the boot around the shifter inside the cab. There was a fill hole up there and he just used a funnel. Food for thought.
-Chris
Old 03-09-2007, 08:29 PM
quicklook2's Avatar
quicklook2
it is easier to do it through the fill hole.
Old 03-10-2007, 08:20 AM
Talyn's Avatar
Talyn
Talyn is offline
When i did mine last, I used this deal that is almost exactly like a graese gun. mater a fact it was a grease gun tube, but it had a long hose on one end, and there was a plunger inside. did about a 1/3rd to a 1/2 a quart at a time, it sucked a lot of air. It was really handy for my transmission, but it was easier to do the 80/90 for the rear end the second tmie outa the fill can.
When i top my tranny or otehr things off in back, i have an old can lying around that i use the spout on the top of it on a quart can, and throw on a clear plastic fill tube.
With the transmission and rear end, you can get it up there just right where it will gravity drain into the tranny.
Old 03-11-2007, 08:43 AM
dgeesaman's Avatar
dgeesaman
dgeesaman is offline
Cheap and easy:
- remove the fill plug and go to the hardware store. Buy a few feet of clear plastic tubing that will fit into the fill hole (use plug for comparison). Make sure you have a funnel that fits the other end of the tube. Route this tube to the fill hole through the engine bay.
It helps a lot get the gear oil warm (by that I mean 70f or more, but not hot). It will pour a lot better warm.
Old 03-11-2007, 10:16 AM
quicklook2's Avatar
quicklook2
a good way to warm oil or additives is to heat water to boiling in microwave and immersing bottle of fluid in the water.
of course taking proper precautions during this.
i disagree with the funnel, if you are working from underneath it makes it hareder to do.
for 3 dollars to buy a pump you really have no savings by just using a tube and funnel. imho.
Old 03-11-2007, 04:27 PM
dgeesaman's Avatar
dgeesaman
I tried that once, and the $3 pump I picked up was so cheap it completely failed to work.
Otherwise, I agree with you. If you can find a cheap pump that actually works, it's the easiest way.
Dave
Old 03-11-2007, 05:22 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
I got a pump from Napa that fits a 5 gal bucket For around 20 bucks and can last a lifetime. Move the pump from the 90w bucket to the ATF bucket to the what ever bucket. And always have plenty around to change and keep all your rigs full. I live a 100 miles from the closest store so having plenty is a motto around here. LOL
Old 03-11-2007, 05:33 PM
quicklook2's Avatar
quicklook2
the pump i have was made by valvoline and screws right on to the plastic bottle after you remove the cap.
i bought it about 3 years ago at pep boys for 3 or 4 bucks.
Fulthrotl
11-01-2012 06:25 PM
mfp4073
1983 - 2012 Ranger & B-Series
23
06-15-2009 08:59 AM
hkmp5sd
Garage & Workshop
13
11-03-2005 03:58 AM
voodoolord
05-16-2005 02:02 PM
Quick Reply: Refilling the trans fluid through the side mounted refill hole
