Ignition Switch Terminals
Old 02-26-2007, 10:53 AM
btacarlton's Avatar
btacarlton
btacarlton is offline
Does anyone know where I can find a diagram showing what each terminal is for on an ignition switch? I know what a couple of the terminals are for, but not sure on the rest. Any help is greatly appreciated. Thanks.
Bill
Old 02-26-2007, 12:23 PM
tractoman's Avatar
tractoman
tractoman is offline
Check here for starters, and ignition wiring.
Good luck
http://www.autozone.com/servlet/UiBr...3d800ce982.jsp
Old 02-26-2007, 12:30 PM
btacarlton's Avatar
btacarlton
That won't help. I have an ignition switch from a 78-79 with no wiring pigtail. Need to find out what all the terminals are for based on how they are labeled. Thanks though.
Old 02-26-2007, 12:46 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
he means this.
The Switch pin-out.
It goes by Vin # for whether it is a 77 or mid-78 +
The switches changed design in mid -1978...
this one pictured below is for the later design.(the one on the right above)
Old 02-26-2007, 01:13 PM
btacarlton's Avatar
btacarlton
Mil1ion - So here's the deal. I am installing a Painless 18 circuit harness in my 77 F250 and am trying to figure out which wires to install where on the switch. I have 2 battery wires which I will obviously put on the battery terminals. I will put the switched accesories on one of the ACC terminals. What about my coil wires? I installed a HEI style distributor. And what about the wire that goes from the ignition switch to the "S" terminal on the relay? Should I put that one on the ST terminal on the ignition switch?
Old Brown F250
07-06-2015 12:13 AM
70Broc
12-19-2012 07:51 PM
alex crease
09-19-2004 11:52 PM
Quick Reply: Ignition Switch Terminals
